TX_FIFO_ALMOST_EMPTY Interrupt Problem
hello,
i work with the IDS014A4 SPIRIT1 WMbus board,
i like to send a frame with the C1 mode(unidirectionel Sent).
my first question is : why the Tx frame preparation is limited with12 bytes ?
my programme can not sendall the data only when i replace :
SpiritSpiWriteLinearFifo(12, PhyTxFrame.DataBuff);
with
SpiritSpiWriteLinearFifo(PhyTxFrame.length, PhyTxFrame.DataBuff);
did I make the right change ?
if not what is the proper solution?
if not, my code does not pass by this condition:
else if (irqStatus.IRQ_TX_FIFO_ALMOST_EMPTY)
Best Regards.
