Nov 10, 2025 8:40 PM UTC
Trying to run SensorDemoBLE on STM32H723ZG using BlueNRG-M0A on the X-Nucleo-IDB05A2
As the title says, I'm trying to just simply run the SensorDemoBLE project. My configurations should be correct, my spi data size is set to 8 bits, and a clock baud rate of 6.0 Mbit/s.
First of, after generating the project there's loads of errors which makes sense since the demo project is on the older side. After fixing most of the errors, and finally compiling and running the project, there's major issues with the hci module. I'm getting timeout errors in the hci_send_req function.
Any help would be aprreciated. Thankyou.
