May 12, 2026 05:14 UTC
The Top marking of ST4SI1M0008SCIFW
Hello Team,
Hope you are well!
Could you confirm if the following top marking on ST4SI1M0008SCIFW is correct?
8942310525
000000923
FN527
Many thanks!
Robert
Peter BENSCH
Peter BENSCHBest answer
May 12, 2026 06:18 UTC
For a question about this device, nobody in the public community will be able to help you, so you should contact the personal Online Support OLS.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
robertw1Author
May 12, 2026 06:40 UTC
Thank you for your advice!
I will submit it on the online support channel.
Robert
