EP Pang
Mar 14, 2018 9:23 AM UTC
STWPLLSim run error
Posted on March 14, 2018 at 10:23
I am using STWPLLSim tool to simulate loop values for STW81200. After installing, when I start the program the following LIBRARY NOT FOUND error occurs:
java.lang.UnsatisfiedLinkError: C:lProg ram Files (x86)1STMicroelectronicsISTWaLSim_v5.31Loaderltimeresp.d11: Can't find dependent libraries
Anybody has solve this problem?
    ngodoanvan
    Jul 23, 2024 2:56 AM UTC
    Do you solve this problem ?
    Oct 15, 2025 8:31 PM UTC
    Just ran into this problem myself.  The fix appears to run the Matlab Compiler Runtime installer "MCRInstaller.exe" from the zip in Windows 7 compatibility mode.
