Jun 26, 2026 01:32 UTC
STWBC86TX and STWLC68RX inband communication
In my application I want to implement an custom inband communication between RX <--> TX。I've gone through the official datasheet but couldn't find clear information about the in-band communication data registers or buffers. Could you point me to any additional reference materials, application notes, or documentation on in-band communication?
Didier HERROUIN
Didier HERROUINBest answer
Jun 29, 2026 13:54 UTC
Dear Frogme,
This is not my intention, but you must understand that Bi-Directional communication is an option in the Qi standard. To use it with STWBC86/STWLC38, you must be in contact with a local ST team (either directly and indirectly through distributor) who can tell you if they can support or not your project and your requests. The docs are not disclosed in a Github space.
Didier HERROUIN
Jun 26, 2026 13:01 UTC
Dear Frogme,
The STWLC68 is not available anymore and it has not been supported for several years now.
It has been replaced by STWLC38.
Please contact your distributor as he will be able to guide you towards the best solution. Indeed, ST support to mass market projects has been limited.
Best regards,
frogmeAuthor
Jun 26, 2026 13:26 UTC
hank you for your reply. I will adopt STWBC86TX paired with STWLC38RX. Could you please send the documents regarding in-band communication to my email?
Additionally, I would like to enquire about further technical support. How can I get in touch with relevant distributors in China? Could you provide their contact information? Thank you very much!
Didier HERROUIN
Jun 26, 2026 13:51 UTC
Dear Frogme,
You can find a lot of ST distributors in China : Contacts - STMicroelectronics, like Future, Arrow, Avnet.
frogmeAuthor
Jun 26, 2026 14:05 UTC
Okay, thank you for your reply. Are there any documents for this wireless charging solution available on GitHub? Please share them with me if possible. Thank you very much!
frogmeAuthor
Jun 26, 2026 22:31 UTC
I have already contacted your distributor (Mouser), who directed me to consult you here. Now you are sending me back to them. All I need is the documentation or sample code for I2C in-band communication between STWLC38 and STWBC86. It is merely a document or code. There is no need to keep passing me back and forth like a hot potato!
Didier HERROUIN
Dear Frogme,
frogmeAuthor
Jun 30, 2026 13:42 UTC
Both Mouser and Digi-Key have clearly stated that they cannot provide additional support, and I am at a loss as to what to do next.
Didier HERROUIN
Jun 30, 2026 13:53 UTC
I am not surprised, at least in Europe, I am not aware of any technical relationship with Digikey and Mouser.
As mentioned, I would recommend Future, Arrow and Avnet.
