Jun 29, 2026 04:15 UTC
STWBC86 and STWLC38 require a firmware update?
Just got a new chip — does it come with factory firmware preloaded? If yes, what version is it? And will I need to re-flash the firmware before it can work properly?
    mƎALLEm
    Jun 29, 2026 08:40 UTC
    STWBC86 and STWLC38 are not STM32 MCUs, so this thread should not be posted in STM32 MCUs Products.
    You've already posted this thread in STM32 MCUs Products and I moved it to "Interface and connectivity ICs" forum board.
    I move this post then...
    Didier HERROUIN
    Jul 3, 2026 14:24 UTC
    Dear frogme,
    If you buy an evaluation kit, the chipsets are pre-loaded.
    If you buy chipsets, they are shipped blank, so you need to load patch + configuration files.
    frogmeAuthor
    Jul 6, 2026 01:18 UTC
    I have designed my own PCB board. Is there a specification document detailing the complete programming procedure and specific operation steps for flashing the patch firmware and configuration files? What operations do I need to perform to program them into the chip?
    Didier HERROUIN
    Jul 10, 2026 15:27 UTC
    You need the GUI and the files to be loaded.
    ST has removed all the collaterals from the website where is mentioned that customers should contact Sales&Marketing or distributor to get the collaterals.
    This local contact is mandatory before starting a design, to check if you can get support.
    Best regards,
