KSiwi
Apr 22, 2019 11:46 AM UTC
STW81200 - how to set second VCO output to work in quadrature?
In the STW81200 it is written that the second VCO output can be set to work in-phase or in quadrature to the primary one.
In the control registers I can not find a field that is responsible for that option. How should I configure the IC to have second VCO output working in quadrature in respect to primary one?
Thank you in advance and best regards,
Krzysztof
