Explorer
Apr 24, 2026 16:32 UTC
STM32H753IITx + ST67W611M1
For STM32H753IITx + ST67W611M1 on a custom board with FreeRTOS:
What is the recommended integration approach for X-CUBE-ST67W61 on STM32H753?
Specifically:
  1. Is STM32H753 officially supported/recommended as a host MCU for ST67W611M1?
  2. For H753, is it recommended to use the middleware directly from CubeMX?
  3. Are there known FreeRTOS version compatibility issues between CubeMX-generated FreeRTOS and X-CUBE-ST67W61 on H753?
Thank you.
Louis AUDOLY
Louis AUDOLYBest answer
Apr 29, 2026 07:29 UTC
Hello @AA_NC ,
There is a dedicated wiki page related to the X-CUBE-ST67W61 pack usage in STM32CubeMX you can find here.
This should answer your questions, but basically yes you can port on all target having the minimum hardware requirements (section 1.1)
Hoping this will help you !
Louis
Louis AUDOLY
Hello @AA_NC ,
Louis
