Jun 2, 2025 4:18 AM UTC
STHV748 Technical Support
Dear Manager.
Hello, I am a student studying at a Korean university.
I am developing a two-channel small ultrasound system.
1. Try to use STHV748, a 4-channel pulser, as a pulsar, and don't use the other 2 channels. Should I connect to GND for channels I'm not currently using?
2. If I want to use it as a three-levels pulser instead of a five-level pulser, should I supply the same high voltage to HVP0_X and HVP1_X? Or should I connect HVP1_X to GND?
Thank you.
From hwijin.
