Erenburg.Evgeny
Mar 11, 2020 10:44 AM UTC
STEVAL-BCN002V1B question.
I try to understand the logic of the kit.
I open STSW-BLUETILE-DK 1.2.0->Project->BLE_Examples->BLE_Beacon
And I see in the main routine
while (1)
	/* BlueNRG-1 stack tick */
	BTLE_StackTick();
	/* Enable Power Save according the Advertising Interval */
 #if ST_USE_OTA_SERVICE_MANAGER_APPLICATION
	if (!isPlugged)
	 if (GPIO_ReadBit(GPIO_Pin_11) == Bit_SET)
		BlueNRG_Sleep(SLEEPMODE_NOTIMER, WAKEUP_IO11, (WAKEUP_IOx_LOW << WAKEUP_IO11_SHIFT_MASK));
	 else
		BlueNRG_Sleep(SLEEPMODE_NOTIMER, WAKEUP_IO11, (WAKEUP_IOx_HIGH << WAKEUP_IO11_SHIFT_MASK));
 #else
	BlueNRG_Sleep(SLEEPMODE_NOTIMER, 0, 0);
 #endif
But where is a periodic data retrieving from the sensors? Where is a beacon updating and advertising? Should I implement it by myself?
