Mar 21, 2025 10:10 AM UTC
ST87M01 - Dual Stack wM-Bus + NB-IOT?
I'm trying to develop a multiprotocol board with Dual Stack wM-Bus + NB-IOT. I found this link:
https://www.st.com/en/wireless-connectivity/nb-iot-products.html
So the ST87M01 module is capable of it.
I have the next questions:
1) The module is sold with the firmware (dual stack) flashed ?
2) The module need extra hardware? It is a noise filter or something, or it just need a STM32L5 as a host?
3) Where can I find documentation about how to control the ST87M01 module from the host? An AT command list or something.
Thanks!
Peter BENSCH
Peter BENSCHBest answer
Mar 21, 2025 2:30 PM UTC
Correct, there is no dual stack built-in.
As I found out after talking to the marketing department, my previous answer was wrong: there is indeed a wM-Bus stack in parallel to the NB-IoT stack, but it is only available as a fallback solution (e.g. if the NB-IoT connection fails in the basement of a building). Details can be found in the press release from @GianlucaT  above.
/Peter
Andrew Neil
Mar 21, 2025 10:25 AM UTC
JuanMarGoAuthor
Mar 21, 2025 10:39 AM UTC
I read every document and didn't find nothing about question 1) and 2).
About the 3) question Section 1.2 "Reference documents" on page 2 of the manual lists "ST87MXX_UM_AT commands description" as document number (2). This indicates that a separate document exists which describes the AT commands for the ST87M01 module family, BUT I can't find it.
Peter BENSCH
Mar 21, 2025 12:10 PM UTC
@JuanMarGo On the overview page it is expressed somewhat ambiguously: ‘suitable for multi-protocol such as wM-Bus as fallback solution’ means that it can be used INSTEAD of wM-Bus if necessary. It therefore does not contain a wM-Bus stack. [wrong statement, see the accepted answer]
Otherwise, all public information can be found on the product's website. For more detailed and additional documents, please contact your local distributor or the local office of STMicroelectronics.
Hope that helps?
/Peter
JuanMarGoAuthor
Mar 21, 2025 12:22 PM UTC
Resuming, the chip has not dual stack inside.
Peter BENSCH
/Peter
Eric DJAKAM
Oct 14, 2025 10:45 AM UTC
Hi Juan, your question is very interesting. Let me close the loop with you in a separate email to check how to best support your application specific case. Kind regards,
