Thierry Didi
Jun 19, 2026 15:38 UTC
ST87M01 does not generate +CEREG 5 URC when it registers to the network
Dear ST team,
I have configured the ST87M01 for sending +CEREG URCs when registration state changes with AT+CEREG=5.
But the modem attaches, but does not sent +CEREG notification (see traces below): Is this a nominal behavior ?
AT+CEREG=5
OK
AT+CEREG=?
+CEREG: (0,1,2,3,4,5)
OK
AT+CEREG?
+CEREG: 5,2,"","",,,,"",""
OK
+CEREG: 0,"","",,,,"",""
+CEREG: 2,"","",,,,"",""
+CSCON: 1
+CSCON: 0
+CSCON: 1
+CSCON: 0
+CSCON: 1
+CSCON: 0
+CSCON: 1
+CSCON: 0
+CSCON: 1
+CSCON: 0
#STENG: ECID=08507721,SRV1=FFB11868,PLMN=0002F802,EDRX=00000001,PSM=00000000,ENRG=000045D7
#SLEEP DRX 2.4s
#WAKEUP DRX
#STENG: ECID=08507721,SRV1=FFB21868,PLMN=0002F802,EDRX=00000001,PSM=00000000,ENRG=00000016
#SLEEP DRX 1.7s
#WAKEUP DRX
Best regards,
Thierry
Thierry Didi
Thierry DidiBest answer
Jun 29, 2026 09:32 UTC
Thanks Didier,
In this case I don’t know what is the problem with my SIM, but it is not in ST87M01. It’s not an issue for me since I have another SIM which works as expected.
So, you can close this ticket from my point of view,
Best Regards
Thierry
Thierry Didi
Jun 22, 2026 11:19 UTC
It looks like the problem comes from the Wireless Logic SIM card which is shiped into the EVKITST87M01-2 dev kit box. This SIM card does not support (as of today) NBIOT in France. This  was confirmed by Wireless Logic support.
I have tested with another SIM card and the +CEREG 5 is generated as expected,
Best Regards
Thierry
Didier HERROUIN
Jun 25, 2026 15:34 UTC
Hello Thierry DIdi,
In fact, the Wireless Logic SIM does support NBIOT in France.
Indeed, I am based in the west of France, and I can use it.
The problem may come from the SIM activation, which must be done using the QR code that is printed in the card flyer. If it is successful, you should receive a mail with « SIM Activation Completed» subject.
If you do not receive the mail, you should retry to activate the SIM.
Best regards,
Thierry Didi
Thierry DidiAuthorBest answer
Thanks Didier,
Best Regards
Thierry
Andrew Neil
Jun 29, 2026 09:59 UTC
It’s the thread creator who “closes” the thread - see:
Didier HERROUIN
Jun 29, 2026 13:46 UTC
Thanks for your feedback Thierry Didi, we are investigating with our SIM provider why you faced such an issue.
