May 19, 2026 11:24 UTC
ST67W611M1: measure frequency of external 32.768 kHz crystal oscillator circuit
Dear all,
is it possible to measure the frequency of the 32,768kHz oscillator (external crystal used) at a buffered pin similar to the MOC pin of the STM32 to tune the frequency by the external capacitors? It would be difficult to do this at pin XTAL32k_IN/OUT without influencing the oscillator frequency.
Best regards,
Peter
TarikAbBest answer
May 19, 2026 12:37 UTC
Hi @PKR
The 32 kHz clock signal cannot be routed on a GPIO to perform such measurement.
mbarg.1
Senior III
May 19, 2026 11:36 UTC
There is a divided output  - check you processor data sheet
PKRAuthor
May 19, 2026 11:58 UTC
I could't finde any hint in the ST67W611M1 module / QCC743 SoC datasheets. Could you provide details?
TarikAbBest answer
Hi @PKR
