Dec 17, 2025 19:21 UTC
ST67W611M1 AT+CIPSTART documentation incomplete
The API documentation for the "AT+CIPSTART" command on the ST67W611M1 chip seems to be incomplete. It is missing the parameter lists for UDP and SSL types.
https://wiki.st.com/stm32mcu/wiki/Connectivity:ST67W611M_AT_Command#AT-2BCIPSTART
The rest of the API is documented on the ESP-AT page:
https://docs.espressif.com/projects/esp-at/en/latest/esp32/AT_Command_Set/TCP-IP_AT_Commands.html#at-cipstart-establish-tcp-connection-udp-transmission-or-ssl-connection
YBOUV.1
YBOUV.1Best answer
Apr 14, 2026 13:12 UTC
Hi @xJIomqygrecz ,
documentation has been updated here.
Please note also that latest X-CUBE-ST67W61 v1.3.0 has been released.
Best regards,
Jan 6, 2026 12:09 UTC
Hi xJIomqygrecz,
Thanks for letting us know. We will update the description which by the way is now here.
Best regards,
YBOUV.1
YBOUV.1Best answer
Hi @xJIomqygrecz ,
Best regards,
