Fabio Ciani
Mar 26, 2018 10:15 AM UTC
SPWF04Sx MQTTCONN problem with Azure
Error while parsing Rich Text Content
    Elio Cometti
    Mar 26, 2018 11:59 AM UTC
    Posted on March 26, 2018 at 13:59
    Dear Fabio,
    The SPWF04S does not allows TLS connections w/ anonymous authentication.
    Actually, during the handshake with the remote server, the SPWF04 try to verify the peers certificate and it need the certificate of the Root CA that signed the server certificate (when connecting from my network access point it requires the Microsoft IT TLS CA 1 certificate).
    The SPWF04 does not have the ability to automatically download the Root CA certificate from the distribution point, hence you have to manually load the Root CA certificate prior to establish the connection to Azure servers.
    Fabio Ciani
    Mar 26, 2018 3:57 PM UTC
    Posted on March 26, 2018 at 15:57
    Hello Elio,
    First of all, thanks for your quick reply.
    Following your tips I've downloaded file 'Microsoft IT TLS CA 1.crt' from '
    https://www.microsoft.com/pki/mscorp/cps/default.htm'';
    Then I've converted it to PEM format with openssl and loaded in
    SPWF04S with this commands:
    AT+S.TLSCERT=content,2
    AT+S.TLSCERT=ca,2037
    -----BEGIN CERTIFICATE-----
    MIIFtDCCBJygAwIBAgIQCLh6UBu+nNotFk0+OVG/VTANBgkqhkiG9w0BAQsFADBa
    MQswCQYDVQQGEwJJRTESMBAGA1UEChMJQmFsdGltb3JlMRMwEQYDVQQLEwpDeWJl
    clRydXN0MSIwIAYDVQQDExlCYWx0aW1vcmUgQ3liZXJUcnVzdCBSb290MB4XDTE2
    MDUyMDEyNTEyOFoXDTI0MDUyMDEyNTEyOFowgYsxCzAJBgNVBAYTAlVTMRMwEQYD
    VQQIEwpXYXNoaW5ndG9uMRAwDgYDVQQHEwdSZWRtb25kMR4wHAYDVQQKExVNaWNy
    b3NvZnQgQ29ycG9yYXRpb24xFTATBgNVBAsTDE1pY3Jvc29mdCBJVDEeMBwGA1UE
    AxMVTWljcm9zb2Z0IElUIFRMUyBDQSAxMIICIjANBgkqhkiG9w0BAQEFAAOCAg8A
    MIICCgKCAgEAjvPxhHV3vL7JpPUWpVMrUGCZ3Nh92SS14XJJN0j+2oaTo30dmksQ
    TXd5fmWpfG424kfUNknQzCQCJxTirnHN2Vd0PBBWGZJKh2L545CNXt7RQRsaph9A
    oiwejlXXJthoQqvsDd7dXmGVs6xsgc6o4K2vX8qm5FFoLif9VCpxpMy7fpLx9lNR
    BTHQGYKwymPQ8koAC830aUv0WpZWOSbJnUsKYzQygKUE5eoot8EAwG0a8CjUSo+A
    rHMZ2PUWL62uCJdiBiz+56XwrUFTf40rMcMUcyHd43hjnFGGtaJIScB5CBVDACuZ
    uEvgx1cHbMS5plQtAVPyo/KkzNnBVPOIzeRME9OKMyFYrRi/vjmBcDlpN/hbpGPv
    CQffhxpix5oIxdEdXmJ2Ad1p5ji7RLAtTTrGLoDgYHJb8szmjlw6IR5dsDkrveoT
    y5bLtmp0jI68DhCfG6VAQY+RXHanDvGqOoe3DHffcWovKGFCLZAPcgWrZ+DBe8uc
    QJrECghEjHw9uqkOHrHZIr0fX0Fqc1T2ZuKg+aY53tJ382kEv7e7PMST/3IEHLU2
    nWh/3/o5T7L2j7kc/63tDhUI44Z88khJd5cW9v0A9k+mXm/nOcBRZT3rsZcw7Oqe
    c/weLKDfi89zX7UOBkIXJpXs2Kkn0NBllFziP8ooKaUg9MjdXbT/5t0CAwEAAaOC
    AUIwggE+MB0GA1UdDgQWBBRYiJ/W3JxIIrcUPv+EiOjmhf/6fTAfBgNVHSMEGDAW
    gBTlnVkwgkdYzKz6CFQ2hns6tQRN8DASBgNVHRMBAf8ECDAGAQH/AgEAMA4GA1Ud
    DwEB/wQEAwIBhjAnBgNVHSUEIDAeBggrBgEFBQcDAQYIKwYBBQUHAwIGCCsGAQUF
    BwMJMDQGCCsGAQUFBwEBBCgwJjAkBggrBgEFBQcwAYYYaHR0cDovL29jc3AuZGln
    aWNlcnQuY29tMDoGA1UdHwQzMDEwL6AtoCuGKWh0dHA6Ly9jcmwzLmRpZ2ljZXJ0
    LmNvbS9PbW5pcm9vdDIwMjUuY3JsMD0GA1UdIAQ2MDQwMgYEVR0gADAqMCgGCCsG
    AQUFBwIBFhxodHRwczovL3d3dy5kaWdpY2VydC5jb20vQ1BTMA0GCSqGSIb3DQEB
    CwUAA4IBAQAwmsadav3vkwgMvoJ3+XagbZ57MCN7qCla9Go+xwsMlt+4S1LkDZw4
    7XhjtXPAHB874Kf/f0lRlTK40Jup5c+WA4GA1UphGP7Easbff0FGIpyAZusPQqDk
    86Qho5jQenT2jOjD0iuqK84RWRlE51wHCULr1/0VTblvbEQ1Joe6oztosIHnIMl/
    EwLzzKufHJVQy65kgLuHCl3OpmuyfeM9NuIpUbcl/NAJ47CtxGIuPn6FJrL2r/dt
    MXPGGZipcpMCzsoLPTzs2XDogPUWq3hqh03GgTeoCnaBBqjvF2B8cBATPDjXM0zk
    N2UI+5Gz6BZ2YSpl9ViUs0UB78BPA3u4
    -----END CERTIFICATE-----
    AT+S.TLSCERT=auth,20
    <e5 9d 59 30 82 47 58 cc ac fa 08 54 36 86 7b 3a b5 04 4d f0> // in binary format
    Then if I list all certificate data with
    AT+S.TLSCERT=content,1
    the reply is
    AT-S.List
    AT-S.CA:1
    AT-S.Cert:0
    AT-S.Key:0
    AT-S.Id:1
    AT-S.OK
    But the problem remains: when I send MQTTCONN command, the reply is always the same:
    AT-S.Skip CA
    AT-S.Skip CA
    AT-S.Certificate Error:23
    AT-S.ERROR:111:Request failed
    Where I'm wrong?
    Thank you.
    Fabio.
    Elio Cometti
    Mar 26, 2018 6:19 PM UTC
    Posted on March 26, 2018 at 18:19
    Hello Fabio,
    my answer was partially incorrect, as 'Microsoft IT TLS CA 1' is the intermediate Authority, while the Root CA is 'Baltimore CyberTrust Root'.
    Please refer to the security application note on how to download the latter certificate from
    <LINK NO LONGER ACTIVE>
    using a browser. Please note that you might need to parse this certificate as it may contain unsupported line terminators (openssl -in BaltimoreCyberTrustRoot.crt -out b.crt). I'm attaching the parsed certificate for your convenience.
    Here below, the certificate in binary format is loaded, so that the key is automatically extracted:
    AT+S.TLSCERT=ca,891
    AT-S.SubjectKeyId:E5:9D:59:30:82:47:58:CC:AC:FA:08:54:36:86:7B:3A:B5:04:4D:F0
    AT-S.OK
    AT-S.List
    AT-S. CA:1
    AT-S.Cert:0
    AT-S.Key:0
    AT-S.Id:1
    AT-S.OK
    AT+S.MQTTCONN=***.azure-devices.net,8883,,2,***.azure-devices.net/DeviceID/api-version=2016-11-14,SharedAccessSignature sr=***.azure-devices.net&sig=KA%2BSBo
    tfK%2BFPFUvKf4Xtb1z3zPLzfplNkMsWmMXu5oo%3D&se=1521901101,DeviceID,,,,,
    AT-S.Skip CA
    AT-S.Loading:1:2
    AT-S.Loading:2:1
    AT-S.Loading:3:1
    AT-S.Loading:3:1
    +WIND:87:MQTT Closed:0:0
    The mqttconn is now failing because the client certificate and key are not loaded.
    Once you have loaded your certificate and key the connect will succede.
    Regards,
    Elio
    ________________
    Attachments :
    b.crt.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HxnT&d=%2Fa%2F0X0000000b1X%2FOyDsiqBTcQvS0p1fwR5mv7PaSVxP0ZSQyZjWxutZvSA&asPdf=false
    b.der.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HxbM&d=%2Fa%2F0X0000000b1W%2FofVpl.K1RQ1nHFRmb5_Fuj_NEYZxxR1agn63yEtBdDs&asPdf=false
    Shep Smith
    Jul 6, 2018 1:53 PM UTC
    Posted on July 06, 2018 at 15:53
    Hello Fabio,
    I know this reply is a couple months too late, but if you are still having the same issue I think I have a solution. I had to do this for a previous project. For my application I was connecting to the Azure IoTHub sending data using MQTT. Their documentation states that you need a security certificate and a SAS token, but for the longest time I couldn't get it to work because of these 2 issues.
    My first issue was getting past the certification:
    In order to get past the cert error you have to have the root CA of the Azure server loaded into the flash. I have had success with it living in the APP flash as well as the SD card if you are using external storage. The interface for loading it dynamically never worked for me (the tls.cert commands and such), so I just followed the instructions in the TCP-IP documentation for this module and made my own cert file with the filename being the subject key. I don't know how to attach it to this comment, but the contents of the file are between the triple quotes. Save it to a new file and remove the triple quotes.
    filename: e59d5930824758ccacfa085436867b3ab5044df0.ca
    content:
    '''-----BEGIN CERTIFICATE-----
    MIIDdzCCAl+gAwIBAgIEAgAAuTANBgkqhkiG9w0BAQUFADBaMQswCQYDVQQGEwJJ
    RTESMBAGA1UEChMJQmFsdGltb3JlMRMwEQYDVQQLEwpDeWJlclRydXN0MSIwIAYD
    VQQDExlCYWx0aW1vcmUgQ3liZXJUcnVzdCBSb290MB4XDTAwMDUxMjE4NDYwMFoX
    DTI1MDUxMjIzNTkwMFowWjELMAkGA1UEBhMCSUUxEjAQBgNVBAoTCUJhbHRpbW9y
    ZTETMBEGA1UECxMKQ3liZXJUcnVzdDEiMCAGA1UEAxMZQmFsdGltb3JlIEN5YmVy
    VHJ1c3QgUm9vdDCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAKMEuyKr
    mD1X6CZymrV51Cni4eiVgLGw41uOKymaZN+hXe2wCQVt2yguzmKiYv60iNoS6zjr
    IZ3AQSsBUnuId9Mcj8e6uYi1agnnc+gRQKfRzMpijS3ljwumUNKoUMMo6vWrJYeK
    mpYcqWe4PwzV9/lSEy/CG9VwcPCPwBLKBsua4dnKM3p31vjsufFoREJIE9LAwqSu
    XmD+tqYF/LTdB1kC1FkYmGP1pWPgkAx9XbIGevOF6uvUA65ehD5f/xXtabz5OTZy
    dc93Uk3zyZAsuT3lySNTPx8kmCFcB5kpvcY67Oduhjprl3RjM71oGDHweI12v/ye
    jl0qhqdNkNwnGjkCAwEAAaNFMEMwHQYDVR0OBBYEFOWdWTCCR1jMrPoIVDaGezq1
    BE3wMBIGA1UdEwEB/wQIMAYBAf8CAQMwDgYDVR0PAQH/BAQDAgEGMA0GCSqGSIb3
    DQEBBQUAA4IBAQCFDF2O5G9RaEIFoN27TyclhAO992T9Ldcw46QQF+vaKSm2eT92
    9hkTI7gQCvlYpNRhcL0EYWoSihfVCr3FvDB81ukMJY2GQE/szKN+OMY3EU/t3Wgx
    jkzSswF07r51XgdIGn9w/xZchMB5hbgF/X++ZRGjD8ACtPhSNzkE1akxehi/oCr0
    Epn3o0WC4zxe9Z2etciefC7IpJ5OCBRLbf1wbWsaY71k5h+3zvDyny67G7fyUIhz
    ksLi4xaNmjICq44Y3ekQEe5+NauQrz4wlHrQMz2nZQ/1/I6eYs9HRCwBXbsdtTLS
    R9I4LtD+gdwyah617jzV/OeBHRnDJELqYzmp
    -----END CERTIFICATE-----'''
    After creating this file create a new flash image and load it onto the board. There is a tutorial of how to do this in the wifi-training documentation, in short you are using the tools provided in the latest firmware package STSW-WIFI004 to create a .img file, then transferring it onto the board using various methods. The one that worked the best for me was hosting a local apache server on a laptop connected to the same wifi network as my spwf04sa module, and using the
    at+s.fsupdate=i,xxx.xxx.xx.208,FatVolume.img,80,0,,
    where the ip address is where the server is listening, and FatVolume.img is your newly compiled image file.
    My second issue was connecting to Azure with the secret, non-documented parameters:
    Here is my code that worked finally.
    AT+S.MQTTCONN=xxx-xxx.azure-devices.net,443,/$iothub/websocket?iothub-no-client-cert=true,2,xxx-xxx.azure-devices.net/deviceID,SharedAccessSignature sr=xxx-xxx.azure-devices.net%2Fdevices%2FdeviceID&sig=igZeiL7d8T66eWHlf4TDtc55pMlbXBae8f%2FE8pEAJWI%3D&se=1529349013,deviceID,60,15,0,,
    And broken down into parameters:
    AT+S.MQTTCONN=
    host_name: (my host name)
    port: (443 for MQTT over TLS)
    path: (/$iothub/websocket?iothub-no-client-cert=true) <- These are the secret, non-documented parameters that let Azure know that you are connecting using Websockets (which is by default how this module connects when using MQTT), and as well letting it know that since you are using a SAS key there is no client certificate that will be sent.
    security: 2 for TLS
    username: my device ID at the end of the endpoint provided by the documentation
    password: SAS token URL encoded
    clientID: my device ID
    the rest are timeout paramters.
    Good luck!
