yoann LBY
Senior
Jan 8, 2018 9:00 AM UTC
SPWF04Sx - delete file in User FS App Disk
Posted on January 08, 2018 at 10:00
hi,
i have a FATVolume.imf with 3 files. I use AT+S.FSUPDATE to download in wifi module.
Is it possible after it to delete 1 file with a cmd equivalent to AT+S.FSD (because this command has effect in the RAM memory volume and external SD card volume only and not User Flash) ?
Yoann
    Elio Cometti
    Elio ComettiBest answer
    Jan 8, 2018 9:59 AM UTC
    Posted on January 08, 2018 at 10:59
    Adding/removing files on a Flash disk is actually not supported. You can only erase it completely or download a new one.
    Best Regards
    Elio Cometti
    Best Regards
