godswordman
Mar 12, 2018 5:15 AM UTC
SPWF04SA WPS problem
Posted on March 12, 2018 at 06:15
When I use the first Firmware version SPWF04S-170216, WPS button can login to access point.
But When I upgrade to new firmware both SPWF04S-170726 and SPWF04S-171117,when push WPS Button it,s not work, it,s show enrollment attemp timed out.
Please check this issue.
    Elio Cometti
    Mar 14, 2018 10:46 AM UTC
    Posted on March 14, 2018 at 11:46
    I'm attaching a console log of a WPS setup to our TP-Link TL-WR740N AP. The SPWF04S is booted with the factory pin (GPIO0) active, and the WIN81 is generated by pressing the WPS button.
    I'm also appending the result of some scan, just to evaluate the crowdedness of the environment.
    Could you tell more about your environment?
    Regards,
    Elio
    ________________
    Attachments :
    WPS.txt.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HxtU&d=%2Fa%2F0X0000000b1w%2FNgK9PXY7qgMxcROlGwUmBIx1PzQkuKzgzGlHR8pSj2A&asPdf=false
