Jobin Joseph
Feb 3, 2018 5:29 AM UTC
SPWF04 Station Disassociation
Posted on February 03, 2018 at 06:29
I am using SPWF04 module for embedded web server application. I can access web pages on the web server from the PC/laptop, but when i access from android phone wifi module reports station disassociation.
    Elio Cometti
    Feb 5, 2018 1:18 PM UTC
    Posted on February 05, 2018 at 14:18
    Can you please detail the scenario when the module reports station disassociation? console log, what is the station doing, ecc.
    I suppose your SPWF04 is configured as MiniAP, isn't it?
    Jobin Joseph
    Feb 5, 2018 4:39 PM UTC
    Posted on February 05, 2018 at 16:39
    The SPWF04 configured as MiniAP. When i connect the wifi on the phone, it showing as connecting...... obtaining ip address..... and this process is continuing. On the console showing station is associated and after few seconds showing station is disassociated and this is process is continuing.
    at
    AT-S.OK
    AT+S.FCFG
    AT-S.OK
    AT+S.RESET
    +WIND:2:Reset
    +WIND:1:Poweron:171117-0328fe3-SPWF04S
    +WIND:13:Copyright (c) 2012-2017 STMicroelectronics, Inc. All rights Reserved:SPWF04SA
    +WIND:65:Factory Reset:1
    +WIND:0:Console active
    +WIND:3:Watchdog Running:20
    +WIND:32:WiFi Hardware Started
    +WIND:21:WiFi Scanning
    +WIND:35:WiFi Scan Complete:00
    AT+S.WIFI=0
    AT-S.OK
    +WIND:49:WPA Terminated:0
    +WIND:38:WiFi Powered Down
    at+s.ssidtxt=Release Tool
    AT-S.OK
    AT+S.SCFG=wifi_priv_mode,1
    AT-S.OK
    AT+S.SCFG=wifi_mode,3
    AT-S.OK
    AT+S.WCFG
    AT-S.OK
    AT+S.RESET
    +WIND:2:Reset
    AT+S.WIFI=1
    AT-S.OK
    +WIND:26:Started AP:Release Tool
    +WIND:24:WiFi Up:0:192.168.0.50
    +WIND:24:WiFi Up::fe80:0:0:0:280:e1ff:febd:ff11
    +WIND:28:Station Associated:24:DA:9B:17:21:8C:0
    +WIND:72:Station Disassociated:24:DA:9B:17:21:8C:8
    AT+S.GCFG
    AT-S.List
    AT-S.Var:nv_manuf=ST
    AT-S.Var:nv_model=SPWF04SA
    AT-S.Var:nv_serial=3817Z24857
    AT-S.Var:nv_wifi_macaddr=00:80:E1:BD:FF:11
    AT-S.Var:standby_time=10
    AT-S.Var:standby_enabled=0
    AT-S.Var:sleep_enabled=0
    AT-S.Var:etf_mode=0
    AT-S.Var:blink_led=1
    AT-S.Var:ext_volume=3
    AT-S.Var:ramdisk_memsize=16
    AT-S.Var:aes128_key=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    AT-S.Var:user_desc=anonymous
    AT-S.Var:python_script=3:/uPython_test.py
    AT-S.Var:python_memsize=32
    AT-S.Var:console_enabled=1
    AT-S.Var:console_speed=115200
    AT-S.Var:console_hwfc=0
    AT-S.Var:console_echo=1
    AT-S.Var:console_errs=2
    AT-S.Var:console_winds=2
    AT-S.Var:console_verbose=1
    AT-S.Var:console_repeater=0x21
    AT-S.Var:console_delimiter=0x2C
    AT-S.Var:console_wind_off_low=0x00000000
    AT-S.Var:console_wind_off_medium=0x00000000
    AT-S.Var:console_wind_off_high=0x00000000
    AT-S.Var:wifi_tx_msdu_lifetime=0
    AT-S.Var:wifi_rx_msdu_lifetime=0
    AT-S.Var:wifi_operational_mode=0x00000011
    AT-S.Var:wifi_beacon_wakeup=1
    AT-S.Var:wifi_beacon_interval=100
    AT-S.Var:wifi_listen_interval=0
    AT-S.Var:wifi_rts_threshold=3000
    AT-S.Var:wifi_ssid=52:65:6C:65:61:73:65:20:54:6F:6F:6C:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    AT-S.Var:wifi_ssid_len=12
    AT-S.Var:wifi_txfail_thresh=5
    AT-S.Var:wifi_dtim_period=1
    AT-S.Var:wifi_add_tim_ie=0
    AT-S.Var:wifi_region=1
    AT-S.Var:wifi_ht_mode=1
    AT-S.Var:wifi_channelnum=6
    AT-S.Var:wifi_opr_rate_mask=0x003FFFCF
    AT-S.Var:wifi_bas_rate_mask=0x0000000F
    AT-S.Var:wifi_mode=3
    AT-S.Var:wifi_auth_type=0
    AT-S.Var:wifi_atim_window=0
    AT-S.Var:wifi_powersave=0
    AT-S.Var:wifi_tx_power=18
    AT-S.Var:wifi_rssi_thresh=0
    AT-S.Var:wifi_rssi_hyst=0
    AT-S.Var:wifi_ap_idle_timeout=120
    AT-S.Var:wifi_beacon_loss_thresh=10
    AT-S.Var:wifi_priv_mode=1
    AT-S.Var:wifi_wep_keys[0]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    AT-S.Var:wifi_wep_keys[1]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    AT-S.Var:wifi_wep_keys[2]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    AT-S.Var:wifi_wep_keys[3]=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    AT-S.Var:wifi_wep_key_lens=00:00:00:00
    AT-S.Var:wifi_wep_default_key=0
    AT-S.Var:wifi_wpa_psk_raw=00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    AT-S.Var:wifi_wpa_psk_text=
    AT-S.Var:wifi_eap_identity=identity
    AT-S.Var:
    mailto:wifi_eap_anon_identity=anonymous@identity.org
    AT-S.Var:wifi_eap_passwd=password
    AT-S.Var:wifi_eap_type=0
    AT-S.Var:wifi_eap_skip_datechecks=0
    AT-S.Var:wifi_wps_walk_time=120
    AT-S.Var:wifi_wps_pin=1234567
    AT-S.Var:ip_sock_memsize=1
    AT-S.Var:ip_sock_threshold=0
    AT-S.Var:ip_dhcp_lease_time=120
    AT-S.Var:ip_macfilter=00:00:00:00:00:00
    AT-S.Var:ip_num_clients=5
    AT-S.Var:ip_allow_port_scans=1
    AT-S.Var:ip_use_v6=1
    AT-S.Var:ip_use_dhcpd=1
    AT-S.Var:ip_use_httpd=1
    AT-S.Var:ip_use_tftpd=1
    AT-S.Var:ip_use_dhcpc=2
    AT-S.Var:ip_hostname=iwm-BD-FF-11
    AT-S.Var:ip_apdomainname=captiveportal.net
    AT-S.Var:ip_apredirect=firstset.html
    AT-S.Var:ip_ipaddr=192.168.0.50
    AT-S.Var:ip_netmask=255.255.255.0
    AT-S.Var:ip_gw=192.168.0.1
    AT-S.Var:ip_dns1=208.67.222.222
    AT-S.Var:ip_dns2=208.67.220.220
    AT-S.Var:ip_local=0:0:0:0:0:0:0:0
    AT-S.Var:ip_dns1v6=0:0:0:0:0:0:0:0
    AT-S.Var:ip_dns2v6=0:0:0:0:0:0:0:0
    AT-S.Var:ip_dhcp_timeout=20
    AT-S.Var:ip_ntp_server1=ptbtime1.ptb.de
    AT-S.Var:ip_ntp_server2=ntp0.ipv6.fau.de
    AT-S.Var:ip_ntp_refresh=3600
    AT-S.Var:ip_ntp_startup=1
    AT-S.Var:ip_mdns_domain_name=SPWF04S-Default
    AT-S.Var:ip_mdns_device_name_ttl=120
    AT-S.Var:ip_mdns_services_name=SPWF04S-WebSrv SPWF04S-TFTPSrv
    AT-S.Var:ip_mdns_services_prot=_http._tcp _tftp._udp
    AT-S.Var:ip_mdns_services_keys=dev1 dev2
    AT-S.Var:ip_mdns_services_vals=number1 number2
    AT-S.Var:ip_mdns_services_port=80 69
    AT-S.Var:ip_mdns_services_ttl=120 60
    AT-S.Var:ip_mdns_startup=01:01
    AT-S.OK
    AT+S.STS
    AT-S.List
    AT-S.Var:build=171117-0328fe3-SPWF04S
    AT-S.Var:fw_version=1.1.0
    AT-S.Var:boot_version=1.0
    AT-S.Var:var_version=2
    AT-S.Var:free_heap=38216
    AT-S.Var:min_heap=35360
    AT-S.Var:system_time=946689264
    AT-S.Var:system_uptime=177
    AT-S.Var:system_sleeptime=0
    AT-S.Var:reset_reason=2
    AT-S.Var:startup=0
    AT-S.Var:random_number=3136117926
    AT-S.Var:gpio_enable=0x0000
    AT-S.Var:app_fs=1
    AT-S.Var:ram_fs=1
    AT-S.Var:user_fs=1
    AT-S.Var:extvol_fs=0
    AT-S.Var:nv_power_cycles=28
    AT-S.Var:nv_wdog_resets=1
    AT-S.Var:nv_reset_cycles=61
    AT-S.Var:wifi_state=10
    AT-S.Var:wifi_own_macaddr=00:80:E1:BD:FF:11
    AT-S.Var:wifi_bssid=00:80:E1:BD:FF:11
    AT-S.Var:wifi_aid=0
    AT-S.Var:wifi_sup_rate_mask=0x003FFFCF
    AT-S.Var:wifi_chan_activity=0x00001FFF
    AT-S.Var:wifi_max_tx_power=18
    AT-S.Var:wifi_gf_mode=0
    AT-S.Var:wifi_reg_country=
    AT-S.Var:wifi_dtim_period=0
    AT-S.Var:wifi_num_assoc=1
    AT-S.Var:ip_from_AutoIP=0
    AT-S.Var:ip_linklocal=fe80:0:0:0:280:e1ff:febd:ff11
    AT-S.OK
    Elio Cometti
    Feb 5, 2018 7:35 PM UTC
    Posted on February 05, 2018 at 19:35
    From log I understand you are setting WEP encryption without a password.
    I'm not sure it is a valid configuration.
    Actually, I cannot get an IP until I set a valid password (40/104 bits) in the SPWF04.
    Ex.:
    pwd=54321
    AT+S.SCFG=wifi_wep_keys[0],3534333231
    AT+S.SCFG=wifi_wep_key_lens,05
    Ex:
    pwd=1234567890123
    AT+S.SCFG=wifi_wep_keys[0],31323334353637383930313233
    AT+S.SCFG=wifi_wep_key_lens,0D
    Elio Cometti
    Feb 6, 2018 9:16 AM UTC
    Posted on February 06, 2018 at 10:16
    Thanks for the log.
    Is the phone disassociating during the access to the web server, or is the phone failing to get an IP?
    Jobin Joseph
    Feb 6, 2018 2:59 PM UTC
    Posted on February 06, 2018 at 14:59
    I am not accessing web server because its not even connecting to the wifi properly. I think phone is  failing to get an IP. When i connect  the wifi on the phone it show
     connecting...... obtaining ip address..... and this process is continues.
    Elio Cometti
    Feb 6, 2018 3:36 PM UTC
    Posted on February 06, 2018 at 15:36
    Can you please capture the DHCP Offer or ACK packet sent by the SPWF04 to the phone and send to me?
    Also please try setting a static IP on the phone for the 'Release Tool' network.
