Tia Meng
Apr 13, 2018 1:15 PM UTC
SPWF04 Standby current
Posted on April 13, 2018 at 15:15
We are using SPWF04 recently and found this module when running at standby mode would draw around >1mA current rather than uA level mentioned in the datasheet (it actually comes to uA for a couple of seconds and turns to 1.7mA after). May I know if SPWF04 could be a compatible replacement for SPWF01, any notice/tips for Hardware redesign, IO config or AT comment settings? Thanks.
    Elio Cometti
    Apr 13, 2018 5:40 PM UTC
    Posted on April 13, 2018 at 19:40
    Dear,
    could you please try setting standby_time=240? You should see the current consumption in the uA level for about 4 minutes.
    Please do not use values greater than 255 as we found a mismatch with what stated in the user manual. The behavior will be aligned to user manual in the next FW release.
    Elio
    Tia Meng
    Tia MengAuthor
    Apr 13, 2018 9:03 PM UTC
    Posted on April 13, 2018 at 21:03
    Hi Elio,
    This is really helpful. I will try and get back. May I know if there is an estimated timing for the next FW and UM? Thank you so much for your kind help. Have a good one.
