Dmytro Medvid
Jan 9, 2018 1:30 PM UTC
SPWF04 HTTP POST Problem
Posted on January 09, 2018 at 14:30
Hello, everybody.
I want to use HTTP client mode. I should send the next message:
api/Tokens?username=test&password=123456789&serialnumber=123456789
to the server:
https://messagebus.example.com
and get the response.
I try to make next:
AT+S.HTTPPOST=messagebus.example.com,/api/Tokens,,,,,Get.txt,Send.txt
In send file i have
username=
test
&password=
123456789
&serialnumber=
123456789
but, server give me Error 404 answer. I think, there is a problem in my AT+S.HTTPOST mesage.
    Gerardo GALLUCCI
    Jan 9, 2018 3:48 PM UTC
    Posted on January 09, 2018 at 16:48
    Probably I'm using wrong URL...
    I get 'DNS error' (502 Bad Gateway) with the browser, and 'Http Client Error:0' with the module. Is it correct 'messagebus.example.com'?
    Dmytro Medvid
    Jan 9, 2018 7:28 PM UTC
    Posted on January 09, 2018 at 19:28
    No, it is just for example.
    Gerardo GALLUCCI
    Jan 10, 2018 11:28 AM UTC
    Posted on January 10, 2018 at 11:28
    Don't know how to help you...
    Try to bypass the send.txt file, and directly put form content into <path&query> parameter. Same result?
    AT+S.HTTPPOST=messagebus.example.com,/api/Tokens?
