Viktor Duma
Oct 11, 2017 6:52 PM UTC
SPWF01SA11 ERROR: SSL/TLS Error: Unable to connect (-308)
Posted on October 11, 2017 at 20:52
Hello! I have an issue with SPWF01SA11 one-way SSL/TLS connection. I am sure I check all similar cases here, but still can't solve my problem. I tried certificates from tutorial en.STSW-TLSpack example_2,
tried to generate my own certificates and got
ERROR: Unable to load CA certificate.
 And now I am trying www.geotrust.com/resources/root-certificates/#.
Through teraterm send commands:
AT+S.TLSCERT2=clean,all
OK
AT+S.SETTIME=1507665904
OK
AT+S.TLSDOMAIN=f_domain,GeoTrust Global CA
OK
AT+S.TLSCERT=f_ca,1216
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
OK
AT+S.TLSCERT=f_content,0
# TLS loaded CERTs:
# CA Cert: YES
# Client Cert: NO
# Client Key: NO
# Domain Name: YES - GeoTrust Global CA
AT+S.SOCKON=ssltest11.bbtest.net,443,s,ind
What is wrong? Please help me! I waste about week for that (((
    gaibotti.adriano
    Oct 12, 2017 7:17 AM UTC
    Posted on October 12, 2017 at 09:17
    Hello Viktor,
    seems you put as domain name the Common Name of the Certification authority (CA).
    You have to put in this field the domain name of the Server you want to connect with. Very likely you will need to use this command:
    AT+S.TLSDOMAIN=f_domain,ssltest11.bbtest.net
    but check inside the server certificate if this is the actual Common Name.
    Viktor Duma
    Oct 12, 2017 3:07 PM UTC
    Posted on October 12, 2017 at 15:07
    Adriano, thank you for your reply. I tried that case too before - doesn't work. Maybe you will see the problem with my local certificates. My steps:
    openssl genrsa -out rootCA.key 2048 \\ CA key
    openssl req -x509 -new -key rootCA.key -days 10000 -out rootCA.crt \\ CA cert
    openssl genrsa -out server.key 2048 \\ server key
    openssl req -new -key server.key -out server.csr \\ server cert
    openssl x509 -req -in server.csr -CA rootCA.crt -CAkey rootCA.key -CAcreateserial -out server.crt -days 5000 \\signature
    openssl x509 -in rootCA.crt -out rootCA.pem -outform PEM
    openssl s_server -key server.key -cert server.crt -tls1_2 -accept 4433 -www \\ runserver
    openssl s_client -connect localhost:4433 -CAfile rootCA.pem // Verify return code: 0 (ok) Extended master secret: yes
    openssl x509 –text –in rootCA.pem –noout // check Looks like keys work with server
    OK
    OK
    AT+S.TLSDOMAIN=f_domain,1.150
    OK
    AT+S.TLSCERT=f_ca,1254
    MIIDYDCCAkigAwIBAgIJAMcDkGsvF9ndMA0GCSqGSIb3DQEBCwUAMEUxCzAJBgNV
    BAYTAkFVMRMwEQYDVQQIDApTb21lLVN0YXRlMSEwHwYDVQQKDBhJbnRlcm5ldCBX
    aWRnaXRzIFB0eSBMdGQwHhcNMTcxMDExMjAxMTA5WhcNNDUwMjI2MjAxMTA5WjBF
    MQswCQYDVQQGEwJBVTETMBEGA1UECAwKU29tZS1TdGF0ZTEhMB8GA1UECgwYSW50
    ZXJuZXQgV2lkZ2l0cyBQdHkgTHRkMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIB
    CgKCAQEAqS2dgNi+60I2991mpne2R0wTiM6r/G4M7kqpg7iTyh0r3WddburetJju
    gAEPaShr19IDj6UoGgpc6+H5vA9/WnhT4Dse/X1NQxqK3rK8wM3lhieMT5xBcOpz
    AhJ3M0T4x3P5VnBpRV38ejZ2XSYdiAW0lQ05UDNg/OF+4MxnTsP9cR8suuRkBh+L
    dV2iFtV4F+1v/g4JN5SwwF/11j/LKw6ga+ZZwuh++rRQB1ZQKGXkJZbVrlQwXFLT
    WXw5IXsg0M3DPLP3l15LSZV/LkRlxoZGBPFKJ/EEURCViEWy+VY93h6zOWRiKUpw
    qE/6hJbpiRw6cJC3aWVGz/YrO2jzIwIDAQABo1MwUTAdBgNVHQ4EFgQUr90WDg24
    EeI6r/SD+sC46Ge6lScwHwYDVR0jBBgwFoAUr90WDg24EeI6r/SD+sC46Ge6lScw
    DwYDVR0TAQH/BAUwAwEB/zANBgkqhkiG9w0BAQsFAAOCAQEAEnORhWbHAMs7jAeP
    tPjd7FMestgWu9FEnZ3paX1S3HyYiiKMiwe6hsCDwg6KHf5+8Kbn+seLP8urlECC
    B0HdDKzHM50MEYqNluFaUvTWAgaIBc+9gtQP2ydK7X69pgFx1cVBax6uzdEWP20X
    uq55050Y+Oxf5l69q/7nM+0pSlU79x7HYnWGcQhJq/IArQiaRjcZiv3u0NcslGez
    HX6tiHzHs9vgUaRGJ9gkrVvtML4mHMeoBUKdhmjaJUSuSFNXwkCesvKDM/Klq9bm
    aHnNXGP8P39Ez5AO+vIebXCFdrzrijoJ+iBETizta9rOFLQSiOOvXh+Y5dCdzN30
    +j4hOA==
    OK
    # TLS loaded CERTs:
    # CA Cert: YES
    # Client Cert: NO
    # Client Key: NO
    # Domain Name: YES - 1.150
    OK
    AT+S.SOCKON=1.150,4433,s,ind
    I tried load certificate like ctrl+c/ctrl+v and send a file through the teraterm. But the same error.
    https://ssl.gstatic.com/ui/v1/icons/mail/images/cleardot.gif
    ________________
    Attachments :
    rootCA.pem.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyNK&d=%2Fa%2F0X0000000b6o%2Fs6NAlyek5hjcVD8JInYbsyAZOEZVyOiSvLpi_BTQUMo&asPdf=false
    server.crt.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyEd&d=%2Fa%2F0X0000000b6l%2Fvkte839fKhmoxdkgkn_9fpDbmu3td3P4uvrBy1SBjek&asPdf=false
    server.key.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyNF&d=%2Fa%2F0X0000000b6n%2FwBi0llE1t155WunwsUa1S_q7rbrYZUbkrZleNu7ysDg&asPdf=false
    gaibotti.adriano
    Oct 12, 2017 3:32 PM UTC
    Posted on October 12, 2017 at 15:32
    Looking at your generated server certificate I've seen that you've used as Common Name (CN) field for you server certificate the string 'server'. Use that as your domain:
    AT+S.TLSDOMAIN=f_domain,server
    Usually this field is filled with the URL of the server, and the TLS protocol check if the server is actually the one claimed by the certificate.
    Let me know if this solves the issue!
    Bye
    Viktor Duma
    Oct 12, 2017 5:18 PM UTC
    Posted on October 12, 2017 at 19:18
    I created new certificates on ubuntu machine (under win10) and run the server. Now I get
    ERROR: SSL/TLS Error: Unable to connect (-150)
    and on server side
    'bad gethostbyaddr
    140682958407320:error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure:s3_pkt.c:1210:'
    When I try to do with the same certificates on windows machine - 'ERROR: Failed to connect' and nothing from the server side.
    About change
    'CR+LF'
     - 'CR' - doesn't work for me. Get ERROR: Unable to load CA certificate. Now, when just copy/past or send file rootCA.pem get Error: Unable to connect (-150). I believe, when server get some response, I am on the correct way )))
    gaibotti.adriano
    Oct 13, 2017 7:44 AM UTC
    Posted on October 13, 2017 at 07:44
    Hello Viktor,
    Error -150 means 'ASN date error, current date before'. So probably you forgot to set the current date correctly or, since you've generated new certificates, you used the old configuration and setup the date as the date of your first tests...
    Viktor Duma
    Oct 13, 2017 1:20 PM UTC
    Posted on October 13, 2017 at 15:20
        Thank you for your time and patience for me! Now it works. It was really difficult to save certificate properly trough the tera term. My colleague wrote the script in C#, and now I can do that with no problem. And one more question. Please suggest me the certificate for access to google.com, for example.  Now I succesful download Entrust Root Certification Authority to the device but can connect only with
    http://www.ssllabs.com
    . Other sites device cant access and rise ERROR: SSL/TLS Error: Unable to connect (-188).
    gaibotti.adriano
    Oct 13, 2017 3:33 PM UTC
    Posted on October 13, 2017 at 15:33
    You're welcome!
    If you want to access to another site, for example google.com, you'll need to download the Certification Authority certificate for that site (
    https://www.thesslstore.com/blog/how-to-view-ssl-certificate-details-in-chrome-56/
    Please note that, since the module has small flash size, it is able to handle just one CA at a time. If you want to connect to several servers you have to cleanup each time the Flash and load new certificate.
    Viktor Duma
    Oct 17, 2017 12:51 PM UTC
    Posted on October 17, 2017 at 14:51
    I am sorry, still, cant connect to google. I got the certificate from
    https://pki.google.com/
     . Also downloaded from the browser.  Tried a lot of different certificates like Geo trust. But I can connect to
     with
    Entrust Root Certificate Authority�?G2.
    Guys, what is wrong?
    OK
    AT+S.SETTIME=1508244012
    OK
    AT+S.TLSDOMAIN=f_domain,google.com
    OK
    AT+S.TLSCERT=f_ca,1501
    MIIEKDCCAxCgAwIBAgIQAQAhJYiw+lmnd+8Fe2Yn3zANBgkqhkiG9w0BAQsFADBC
    MQswCQYDVQQGEwJVUzEWMBQGA1UEChMNR2VvVHJ1c3QgSW5jLjEbMBkGA1UEAxMS
    R2VvVHJ1c3QgR2xvYmFsIENBMB4XDTE3MDUyMjExMzIzN1oXDTE4MTIzMTIzNTk1
    OVowSTELMAkGA1UEBhMCVVMxEzARBgNVBAoTCkdvb2dsZSBJbmMxJTAjBgNVBAMT
    HEdvb2dsZSBJbnRlcm5ldCBBdXRob3JpdHkgRzIwggEiMA0GCSqGSIb3DQEBAQUA
    A4IBDwAwggEKAoIBAQCcKgR3XNhQkToGo4Lg2FBIvIk/8RlwGohGfuCPxfGJziHu
    Wv5hDbcyRImgdAtTT1WkzoJile7rWV/G4QWAEsRelD+8W0g49FP3JOb7kekVxM/0
    Uw30SvyfVN59vqBrb4fA0FAfKDADQNoIc1Fsf/86PKc3Bo69SxEE630k3ub5/DFx
    +5TVYPMuSq9C0svqxGoassxT3RVLix/IGWEfzZ2oPmMrhDVpZYTIGcVGIvhTlb7j
    gEoQxirsupcgEcc5mRAEoPBhepUljE5SdeK27QjKFPzOImqzTs9GA5eXA37Asd57
    r0Uzz7o+cbfe9CUlwg01iZ2d+w4ReYkeN8WvjnJpAgMBAAGjggERMIIBDTAfBgNV
    HSMEGDAWgBTAephojYn7qwVkDBF9qn1luMrMTjAdBgNVHQ4EFgQUSt0GFhu89mi1
    dvWBtrtiGrpagS8wDgYDVR0PAQH/BAQDAgEGMC4GCCsGAQUFBwEBBCIwIDAeBggr
    BgEFBQcwAYYSaHR0cDovL2cuc3ltY2QuY29tMBIGA1UdEwEB/wQIMAYBAf8CAQAw
    NQYDVR0fBC4wLDAqoCigJoYkaHR0cDovL2cuc3ltY2IuY29tL2NybHMvZ3RnbG9i
    YWwuY3JsMCEGA1UdIAQaMBgwDAYKKwYBBAHWeQIFATAIBgZngQwBAgIwHQYDVR0l
    BBYwFAYIKwYBBQUHAwEGCCsGAQUFBwMCMA0GCSqGSIb3DQEBCwUAA4IBAQDKSeWs
    12Rkd1u+cfrP9B4jx5ppY1Rf60zWGSgjZGaOHMeHgGRfBIsmr5jfCnC8vBk97nsz
    qX+99AXUcLsFJnnqmseYuQcZZTTMPOk/xQH6bwx+23pwXEz+LQDwyr4tjrSogPsB
    E4jLnD/lu3fKOmc2887VJwJyQ6C9bgLxRwVxPgFZ6RGeGvOED4Cmong1L7bHon8X
    fOGLVq7uZ4hRJzBgpWJSwzfVO+qFKgE4h6LPcK2kesnE58rF2rwjMvL+GMJ74N87
    L9TQEOaWTPtEtyFkDbkAlDASJodYmDkFOA/MgkgMCkdm7r+0X8T/cKjhf4t5K7hl
    MqO5tzHpCvX2HzLc
    OK
    # TLS loaded CERTs:
    # CA Cert: YES
    # Client Cert: NO
    # Client Key: NO
    # Domain Name: YES - google.com
    OK
    AT+S.SOCKON=www.google.com,443,s,ind
    ERROR: SSL/TLS Error: Unable to connect (-322)
    gaibotti.adriano
    Oct 17, 2017 3:36 PM UTC
    Posted on October 17, 2017 at 15:36
    Hi Viktor,
    the error -322 means that the domain name is wrong. Try to use as domain name
    http://www.google.com
    Cheers
    Viktor Duma
    Oct 17, 2017 1:48 PM UTC
    Posted on October 17, 2017 at 15:48
    I did it before.  -188 ASN sig error, no CA signer to verify certificate
    Any ideas?
    # CA Cert: YES
    # Client Cert: NO
    # Client Key: NO
    # Domain Name: YES - www.google.com
    O
    Receive: K
    Sent: AT+S.SOCKON=www.google.com,443,s,ind
    Receive:
    Receive: connect (-188)
    gaibotti.adriano
    Oct 17, 2017 4:16 PM UTC
    Posted on October 17, 2017 at 16:16
    This happens because the certificate you have loaded is too big for the module's RAM availability...the module isn't able to handle certificates greater than 1.3 KBs when dealing with one-way authentication and, when using muthual authentication, the overall size of the certificates and private key should be less than 3KBs.
    Please refer to
    http://www.st.com/content/ccc/resource/technical/document/application_note/f2/8e/ae/8f/fe/77/44/aa/DM00176553.pdf/files/DM00176553.pdf/jcr:content/translations/en.DM00176553.pdf
      for more informations...
    Viktor Duma
    Oct 17, 2017 2:26 PM UTC
    Posted on October 17, 2017 at 16:26
    I read that. What can you advise me when I need do that? Use mutual connection? Thank you!
    gaibotti.adriano
    Oct 17, 2017 5:13 PM UTC
    Posted on October 17, 2017 at 17:13
    In this case there is no solution unfortunately...the mutual authentication is used only when the server requests it (and https doesn't use any mutual authentication).
    But consider that, usually, in a IoT scenario, clouds platforms (AWS, Azure etc.) use smaller certificates with respect to the ones used for https (the latter case is for desktop, while IoT clouds are intended for very constrained devices).
    One advice to you is to use, in case of mutual authentication, private keys and certificates ECDSA-signed that, at the same level of security of RSA-signed certificates, are smaller. For example with Amazon AWS it is possible to use them.
    Viktor Duma
    Oct 18, 2017 12:58 PM UTC
    Posted on October 18, 2017 at 14:58
    I understand. Thank you for support! Yesterday I download the certificate for Amazon, according to tutorial AN4963
    50/61 ,
    and it works. But when I do the same for other sites - doesn't work. Certificates about 1200 kb. What the secret? )))
