victorgarcia
Dec 2, 2014 12:48 PM UTC
SPWF01SA problems to connect to access point
Posted on December 02, 2014 at 13:48
Hi all
First of all excuse my english
I'm trying to connect my SPWF01SA to an access point but I´m doing something wrong because I don't get access to the wifi net. I think that my configuration is correct but something happens
this is a log of the process:
+WIND:1:Poweron (140225-02d76c4-SPWF01S)<CR><LF>
<CR><LF>
+WIND:13:ST SPWF01SA1 IWM: Copyright (c) 2012-2014 STMicroelectronics, Inc.  All rights Reserved.<CR><LF>
<CR><LF>
+WIND:3:Watchdog Running<CR><LF>
<CR><LF>
+WIND:0:Console active<CR><LF>
<CR><LF>
+WIND:32:WiFi Hardware Started<CR><LF>
<CR><LF>
+WIND:21:WiFi Scanning<CR><LF>
<CR><LF>
+WIND:35:WiFi Scan Complete (0x0)<CR><LF>
<CR><LF>
<CR><LF>
<CR><LF>
<CR><LF>
This is the config:
AT&V<CR><LF>
# Dumping All Configuration Keys:<CR><LF>
#  nv_manuf = ST<CR><LF>
#  nv_model = SPWF01SA1<CR><LF>
#  nv_serial = 0614D10309<CR><LF>
#  nv_wifi_macaddr = 00:80:E1:FF:BC:7B<CR><LF>
#  blink_led = 1<CR><LF>
#  user_desc = anonymous<CR><LF>
#  localecho1 = 1<CR><LF>
#  console_uart = 1<CR><LF>
#  console1_speed = 115200<CR><LF>
#  console1_hwfc = 0<CR><LF>
#  console1_enabled = 1<CR><LF>
#  console2_speed = 115200<CR><LF>
#  console2_enabled = 0<CR><LF>
#  localecho2 = 1<CR><LF>
#  console3_enabled = 0<CR><LF>
#  console3_speed = 115200<CR><LF>
#  localecho3 = 1<CR><LF>
#  wifi_tx_msdu_lifetime = 0<CR><LF>
#  wifi_rx_msdu_lifetime = 0<CR><LF>
#  wifi_rts_threshold = 3000<CR><LF>
#  wifi_ssid =
46:54:45:2D:35:35:30:35
:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00<CR><LF>
#  wifi_ssid_len = 8<CR><LF>
#  wifi_mode = 1<CR><LF>
#  wifi_auth_type = 0<CR><LF>
#  wifi_rssi_thresh = 0<CR><LF>
#  wifi_rssi_hyst = 0<CR><LF>
#  wifi_ap_idle_timeout = 120<CR><LF>
#  wifi_beacon_loss_thresh = 10<CR><LF>
#  wifi_priv_mode = 0<CR><LF>
#  wifi_wep_keys[0] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00<CR><LF>
#  wifi_wep_keys[1] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00<CR><LF>
#  wifi_wep_keys[2] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00<CR><LF>
#  wifi_wep_keys[3] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00<CR><LF>
#  wifi_wep_key_lens = 00:00:00:00<CR><LF>
#  wifi_wep_default_key = 0<CR><LF>
#  wifi_wpa_psk_raw = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00<CR><LF>
#  wifi_wpa_psk_text =
gtmq-dua
l<CR><LF>
#  ip_use_dhcp = 1<CR><LF>
#  ip_use_httpd = 1<CR><LF>
#  ip_mtu = 1500<CR><LF>
#  ip_hostname = iwm-FF-BC-7B<CR><LF>
#  ip_apdomainname = captiveportal.net<CR><LF>
#  ip_ipaddr = 192.168.0.50<CR><LF>
#  ip_netmask = 255.255.255.0<CR><LF>
#  ip_gw = 192.168.0.1<CR><LF>
#  ip_dns = 192.168.0.1<CR><LF>
#  ip_http_get_recv_timeout = 1000<CR><LF>
#  ip_dhcp_timeout = 20<CR><LF>
this is a scan to check that the module is seeing my net
AT+S.SCAN<CR><LF>
1:<HT> BSS F8:8E:85:C5:E1:5A CHAN: 01 RSSI: -87 SSID: 'MOVISTAR_E159' CAPS: 0411 WPA <CR><LF>
2:<HT> BSS 00:1A:2B:B1:43:E8 CHAN: 01 RSSI: -90 SSID: '\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00' CAPS: 0411 WPA WPS <CR><LF>
3:<HT> BSS 00:26:18:90:38:51 CHAN: 01 RSSI: -90 SSID: 'WebSTAR' CAPS: 0411 <CR><LF>
4:<HT> BSS 9C:80:DF:87:80:EB CHAN: 02 RSSI: -90 SSID: 'Orange-80E9' CAPS: 0431 WPA WPA2 WPS <CR><LF>
5:<HT> BSS 38:72:C0:DF:98:B6 CHAN: 03 RSSI: -90 SSID: 'luis-puy' CAPS: 0411 WPA <CR><LF>
6:<HT> BSS 88:E3:AB:8F:42:C7 CHAN: 04 RSSI: -89 SSID: 'vodafone42BE' CAPS: 0411 WPA2 WPS <CR><LF>
7:<HT> BSS 00:1A:2B:69:01:81 CHAN: 05 RSSI: -83 SSID: 'WLAN_9E' CAPS: 0411 WPA <CR><LF>
8:<HT> BSS D0:AE:EC:C4:FD:08 CHAN: 06 RSSI: -71 SSID: 'WLAN_FD08' CAPS: 0C31 WPA WPS <CR><LF>
9:<HT> BSS 00:25:69:A1:55:06 CHAN: 06 RSSI: -83 SSID: '
FTE-5505
' CAPS: 0411 WPA2 <CR><LF>
10:<HT> BSS DC:53:7C:05:26:31 CHAN: 07 RSSI: -92 SSID: 'ONOC963' CAPS: 0411 WPA WPA2 WPS <CR><LF>
11:<HT> BSS C0:3F:0E:FF:75:82 CHAN: 11 RSSI: -91 SSID: 'ONO7582' CAPS: 0411 WPA WPA2 <CR><LF>
12:<HT> BSS 00:1A:2B:42:E4:98 CHAN: 11 RSSI: -85 SSID: 'JAZZTEL_18' CAPS: 0411 <CR><LF>
13:<HT> BSS 00:1A:2B:5C:92:FB CHAN: 11 RSSI: -86 SSID: 'JAZZTEL_DA' CAPS: 0411 <CR><LF>
Could you help me to see where is the mistake? The documentation is quite limited
Thanks!
    Gerardo GALLUCCI
    Dec 2, 2014 2:53 PM UTC
    Posted on December 02, 2014 at 15:53
    Hi Victor,
    ''wifi_priv_mode = 0'' means no security. Is it correct?
    Try:
    at+s.scfg=wifi_priv_mode,2
    at&w
    at+cfun=1
    let me know
    j
    ps:
    140225-02d76c4 is an old version. I suggest to contact your local ST distributors, and update it.
    victorgarcia
    Dec 3, 2014 8:50 AM UTC
    Posted on December 03, 2014 at 09:50
    Hi Gerardo
    You are right! this is the mistake, now the module is connecting. Thanks for the quickly reply, and thanks for the advice, I´ll try to upgrade it.
    <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    <CR><LF>
    +WIND:19:WiFi Join: 00:25:69:A1:55:06<CR><LF>
    <CR><LF>
    +WIND:25:WiFi Association with 'FTE-5505' successful<CR><LF>
    <CR><LF>
    +WIND:51:WPA Handshake Complete<CR><LF>
    <CR><LF>
    +WIND:24:WiFi Up: 192.168.1.11<CR><LF>
    Regards!
