Manfred Dietrich
Jan 12, 2017 12:21 PM UTC
SPWF01SA NTP client
Posted on January 12, 2017 at 13:21
Is there a sample implementation of a NTP client to get the time from a timeserver?
I use the SPWF01SA together with a STM32F401.
BR,
Manfred
#spwf01-ntp
    Gerardo GALLUCCI
    Gerardo GALLUCCIBest answer
    Jan 12, 2017 6:58 PM UTC
    Posted on January 12, 2017 at 19:58
    Hi Manfred,
    if SimpleNTP is enough, you can open a simple UDP socket  (AT+S.SOCKON) and write (AT+S.SOCKW) a 48 byte requesto to server. Than expect a 48 byte reply, and read (AT+S.SOCKR) it.
    http://ceng393.cankaya.edu.tr/uploads/files/file/ntp_project-1.pdf
     a simple flow.
    Gerardo GALLUCCI
    Hi Manfred,
     a simple flow.
    Manfred Dietrich
    Jan 12, 2017 8:09 PM UTC
    Posted on January 12, 2017 at 20:09
    Hi Gerardo,
    SimpleNTP is accurate enough.
    Thanks for your quick answer.
    Manfred
