Dec 13, 2018 8:57 AM UTC
SPWF01SA Deauthentication FW 3.6
- 4 replies
- 970 views
I have a problem with SPWF01SA WiFi module with FW 3.6. The module is connected to a WiFi network, generated by a router (STAtion Mode), with active DHCP. A socket server is opened on port 80. I have seen that after a day the module IP is changed due to a Deauthentication. Herein you can find the communication between module and router, where you can see at 101149 sec the Deauthentication Packet (in this case after deauthentication the router assigns the same IP, but not always happens). What is the cause of this?
Thanks a lot,
Giulio
