Darek Mhl
Jun 27, 2018 6:31 PM UTC
SPWF01SA.11 start problem after save settings
Posted on June 27, 2018 at 20:31
I have problem with this wifi module.
After I saved configuration settings  in module (act as wifi client) he does not starts at all.
I thought that I destroyed some internal file system structures/module config so I tried to enter into bootloader mode to overwrite firmware and factory settings but without success. It looks like that the module does not response at all.
Information about my module:
+WIND: Power On (170111-665d284-SPWF01S)
I attached boot sequences screen from logic analyzer.
Does anyone has idea how to start this module or how to make detail diagnosis of this case?
#spwf01sa #wifi-spwf01sa
    Darek Mhl
    Darek MhlAuthor
    Jun 28, 2018 8:12 AM UTC
    Posted on June 28, 2018 at 10:12
    OK, I figured out  how to enter to factory reset mode:
    WLAN_RESTORE_Pin = 1
    WLAN_PWR_EN_Pin = 0   ; disable power supply to module
    Delay(50)
    WLAN_PWR_EN_Pin = 1   ; power up module
    Delay(100)
    WLAN_BOOT = 0
    nRESET = 0
    Delay(100)
    nRESET = 1
    Elio Cometti
    Jun 28, 2018 12:30 PM UTC
    Posted on June 28, 2018 at 14:30
    Dear,
    you should see the power led (GPIO14) lit for a while when deasserting the reset line (or release the reset button on X-Nucleo), this indicates the WiFi module is booting.
    In this case please try restoring to factory settings by pulling GPIO0 High at boot.
    Regards,
    Elio
    Elio Cometti
    Jun 28, 2018 2:35 PM UTC
    Posted on June 28, 2018 at 14:35
    sorry, I missed your 2nd comment.
    Likely the spwf01's uart was configured with flow control and the flow control line was blocking the spwf01's uart.
