anonymous.230621_1419
Jul 27, 2015 12:03 PM UTC
SPWF01SA.11 connection to AP
Posted on July 27, 2015 at 14:03
The original post was too long to process during our migration. Please click on the attachment to read the original post.
    Gerardo GALLUCCI
    Jul 27, 2015 12:21 PM UTC
    Posted on July 27, 2015 at 14:21
    Please update your FW.
    Are you sure your AP is set with WPA2 key? Scan command gives you ''WPA'', not ''WPA2''...
    j
    Jul 27, 2015 12:41 PM UTC
    Posted on July 27, 2015 at 14:41
    Hello Gerado,
    yes, you are right Key is WPA not WPA2.
    Is there any difference, in AT Commands ?
    Or just FW upgrade will fix it ?
    Best regards,
    Alex
    Gerardo GALLUCCI
    Jul 27, 2015 12:48 PM UTC
    Posted on July 27, 2015 at 14:48
    I don't know if it fix the problem, but updating the FW we'll be able to get the deauthentication reason code after WIND:40.
    It's a better starting point...
    j
    Jul 27, 2015 1:44 PM UTC
    Posted on July 27, 2015 at 15:44
    I've tested it now with an other Ap.
    The module ony has problems with WPA. WPA2 is working fine
    Thanks for your help.
