SPWF01.SA,how to configure 11B,11G or 11N
Posted on July 24, 2015 at 11:36
My product will do FCC
certification,and the wifi module in my product is SPWF01.SA.
As FCC certification requiement,I need to set SPWF01SA as below:
11B-Ch1,Ch7,Ch13
11G-Ch1,Ch7,Ch13
11N-Ch1,Ch7,Ch13
I can configure the channel num by AT command successfully,but I don’t know how to configue the module to 11B ,11G or 11N.
Pls help me for this problem.
Peter
    Gerardo GALLUCCI
    Posted on July 27, 2015 at 14:25
    you can use:
    - wifi_opr_rate_mask to set b/g/n (together with wifi_ht_mode for n)
    - wifi_channelnum to set the channel (if you are in miniAP mode)
    jerry
