basavanagouda
Sep 1, 2016 10:45 AM UTC
spwf01 module Timing Issue
Posted on September 01, 2016 at 12:45
I observed followings while communicating between two
spwf01
modules:
  • At the Client side when its try to connect to server I’m using AT+S.SOCKON command to connect.
  • In this command I can pass “ind�? parameter which can indicate data arrival at the client side with “+WIND:55:Pending Data�? on UART interrupt .
  • Client side it is taking 500ms to receive WIND:55:Pending Data: interrupt.
  • Server to client data transmission it takes only 5 to 6ms.
Please suggest how to solve this time delay at the client side.
Thank you
Basavanagouda
    Gerardo GALLUCCI
    Sep 2, 2016 4:00 PM UTC
    Posted on September 02, 2016 at 18:00
    Please post some other info: FW version, status dump, average RTT of the network, kind of socket used, etc...
    basavanagouda
    Sep 6, 2016 8:42 AM UTC
    Posted on September 06, 2016 at 10:42
    Thank you for your reply
    Below details I got for AT&V command, and I'm using TCP protocol for communication.
    +D:24:WiFi Up:4.2
    Dumping All Configuration Keys:
    nv_manuf = ST
    nv_model = SPWF01SA1
    nv_serial = 5114D22308
    nv_wifi_macaddr = 00:80:E1:B4:AF:6A
    blink_led = 0
    wind_off_low = 0x00000000
    wind_off_medium = 0x00000000
    wind_off_high = 0x00000000
    user_desc = anonymous
    escape_seq = at+s
    localecho1 = 0
    console1_speed = 115200
    console1_hwfc = 0
    console1_enabled = 1
    sleep_enabled = 0
    standby_enabled = 0
    standby_time = 10
    wifi_tx_msdu_lifetime = 0
    wifi_rx_msdu_lifetime = 0
    wifi_operational_mode = 0x00000011
    wifi_beacon_wakeup = 1
    wifi_beacon_interval = 100
    wifi_listen_interval = 0
    wifi_rts_threshold = 100
    wifi_ssid = 4C:41:4E:44:44:4F:4F:52:31:41:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    wifi_ssid_len = 11
    wifi_channelnum = 6
    wifi_opr_rate_mask = 0x00003FCF
    wifi_bas_rate_mask = 0x0000000F
    ifi_mode = 1
    ifi_auth_type = 0
    ifi_atim_window = 0
    ifi_powersave = 0
    ifi_tx_power = 18
    ifi_rssi_thresh = 0
    ifi_rssi_hyst = 0
    ifi_ap_idle_timeout = 120
    ifi_beacon_loss_thresh = 10
    ifi_priv_mode = 0
    ifi_wep_keys[0] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    fi_wep_keys[1] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    fi_wep_keys[2] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    i_wep_keys[3] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    i_wep_key_lens = 00:00:00:00
    i_wep_default_key = 0
    i_wpa_psk_raw = 7A:35:61:54:E0:E1:89:E8:14:95:DB:57:0E:BA:6F:71:FC:BB:33:CD:77:E3:43:76:B8:6E:22:4D:56:39:E7:92
    _wpa_psk_text = LANDDOOR1AP
    se_dhcp = 2
    se_httpd = 1
    tu = 1500
    ostname = iwm-B4-AF-6A
    pdomainname = captiveportal.net
    paddr = 4.1
    etmask = 0
    w = 0.1
    ns = 0.1
    ttp_get_recv_timeout = 3000
    cp_timeout = 20
    ckd_timeout = 250
    Thank you
    Basavanagouda.
    basavanagouda
    Sep 6, 2016 8:45 AM UTC
    Posted on September 06, 2016 at 10:45
    I have observed Station mode module is taking more time(40sec to 1minute ) to search the access point module.
    How to reduce this time?
    kindly give suggestion.
    Thank you
    Basavanagouda.
    Gerardo GALLUCCI
    Sep 6, 2016 8:58 AM UTC
    Posted on September 06, 2016 at 10:58
    AT+S.STS also
    As many info you can share, as fast we can solve...
    ps: check your UART driver. you are loosing a lot of bytes. consider to use an rs232/usb converter at this early stage, removing external MCU.
    basavanagouda
    Sep 6, 2016 9:41 AM UTC
    Posted on September 06, 2016 at 11:41
    Hi
    Below information at the Station mode module.
    # Status & Statistics:
    #  version = 141106-0950875-SPWF01S
    #  reset_reason = 2
    #  conf_flag = 5
    #  system_uptime = 571
    #  system_sleeptime = 0
    #  gpio_enable = 0
    #  captiveportal = 0
    #  wifi_state = 10
    #  wifi_bssid = 00:80:E1:B4:85:06
    #  wifi_aid = 1
    #  wifi_channelnum = 6
    # wifi_sup_rate_mask = 0x003FFFCF
    #  wifi_bas_rate_mask = 0x00000000
    # wifi_chan_activity2 = 0x00003FFF
    #  wifi_max_tx_power = 18
    # wifi_reg_country = GB
    # wifi_dtim_period = 0
    # wifi_sleeping = 1
    # wifi_num_assoc = 0
    # ip_ipaddr = 192.168.4.2
    # ip_netmask = 255.255.255.0
    # ip_gw = 192.168.4.1
    # ip_dns = 192.168.4.1
    # ip_sock_open = 1
    # ip_sockd_port = 0
    # free_heap = 20568
    # min_heap = 20008
    # current_time = 1054
    OK
    Below information at the Access mode module.
    # Dumping All Configuration Keys:
    #  nv_manuf = ST
    #  nv_model = SPWF01SA1
    #  nv_serial = 5114D22308
    #  nv_wifi_macaddr = 00:80:E1:B4:AF:6A
    #  blink_led = 0
    #  wind_off_low = 0x00000000
    #  wind_off_medium = 0x00000000
    #  wind_off_high = 0x00000000
    #  user_desc = anonymous
    #  escape_seq = at+s
    #  localecho1 = 0
    #  console1_speed = 115200
    #  console1_hwfc = 0
    #  console1_enabled = 1
    #  sleep_enabled = 0
    #  standby_enabled = 0
    #  standby_time = 10
    #  wifi_tx_msdu_lifetime = 0
    #  wifi_rx_msdu_lifetime = 0
    #  wifi_operational_mode = 0x00000011
    #  wifi_beacon_wakeup = 1
    #  wifi_beacon_interval = 100
    #  wifi_listen_interval = 0
    #  wifi_rts_threshold = 100
    #  wifi_ssid = 4C:41:4E:44:44:4F:4F:52:31:41:50:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    #  wifi_ssid_len = 11
    #  wifi_opr_rate_mask = 0x00003FCF
    #  wifi_bas_rate_mask = 0x0000000F
    #  wifi_mode = 3
    #  wifi_auth_type = 0
    #  wifi_atim_window = 0
    #  wifi_powersave = 0
    #  wifi_tx_power = 18
    #  wifi_rssi_thresh = 0
    #  wifi_rssi_hyst = 0
    #  wifi_ap_idle_timeout = 120
    #  wifi_beacon_loss_thresh = 10
    #  wifi_priv_mode = 0
    #  wifi_wep_keys[0] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    #  wifi_wep_keys[1] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    #  wifi_wep_keys[2] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    #  wifi_wep_keys[3] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
    #  wifi_wep_key_lens = 00:00:00:00
    #  wifi_wep_default_key = 0
    #  wifi_wpa_psk_raw = 7A:35:61:54:E0:E1:89:E8:14:95:DB:57:0E:BA:6F:71:FC:BB:33:CD:77:E3:43:76:B8:6E:22:4D:56:39:E7:92
    #  wifi_wpa_psk_text = LANDDOOR1AP
    #  ip_use_dhcp = 2
    #  ip_use_httpd = 1
    #  ip_mtu = 1500
    #  ip_hostname = iwm-B4-AF-6A
    #  ip_apdomainname = captiveportal.net
    #  ip_ipaddr = 192.168.4.1
    #  ip_gw = 192.168.0.1
    #  ip_dns = 192.168.0.1
    #  ip_http_get_recv_timeout = 3000
    #  ip_dhcp_timeout = 20
    #  ip_sockd_timeout = 250
    #  reset_reason = 2
    #  conf_flag = 5
    #  system_uptime = 368
    #  gpio_enable = 0
    #  captiveportal = 0
    #  wifi_state = 5
    #  wifi_bssid = 00:00:00:00:00:00
    #  wifi_aid = 0
    #  wifi_channelnum = 0
    #  wifi_sleeping = 0
    #  ip_ipaddr = 0.0.0.0
    #  ip_netmask = 0.0.0.0
    #  ip_gw = 0.0.0.0
    #  ip_dns = 0.0.0.0
    #  ip_sock_open = 0
    #  ip_sockd_port = 0
    #  free_heap = 21544
    #  min_heap = 20008
    #  current_time = 495
    OK
    Basvanagouda
    Gerardo GALLUCCI
    Sep 6, 2016 10:11 AM UTC
    Posted on September 06, 2016 at 12:11
    you are using a 2 years old release.
    First of all, please update to FW3.5
    basavanagouda
    Sep 6, 2016 10:22 AM UTC
    Posted on September 06, 2016 at 12:22
    Oops:(
    Can you please share the latest version firmware and Updating procedure from UART.
    It will help me lot.
    Thank you
    Basavanagouda
    basavanagouda
    Sep 6, 2016 10:36 AM UTC
    Posted on September 06, 2016 at 12:36
    If I update the firmware version, above issue can be resolved?
    it already took lot of my time to solving it.
    Please let me, If its can solve my issue it will help me lot
    Basavanagouda
    Gerardo GALLUCCI
    Sep 6, 2016 11:20 AM UTC
    Posted on September 06, 2016 at 13:20
    Try new FW and let me know.
    E.g. FW3.5 works better when looking for hidden networks
    basavanagouda
    Sep 6, 2016 11:25 AM UTC
    Posted on September 06, 2016 at 13:25
    Could you please share me the link where I can download FW3.5  and share the firmware updating process from the UART.
    Basavanagouda.
