rick2399
Dec 19, 2014 8:13 PM UTC
Spirit1 Evaluation
Posted on December 19, 2014 at 21:13
From the landing page on the SPIRIT1 Radio, if i want to operate 915/922 MHz Band - what is required to get started?  Can I use two of the Dongles evaluation modules -
STEVAL0IKRV001V5 (on a computer perhaps with 2 USB ports) or one each of the STEVAL-IKR002V5 and the above USB Dongle part STEVAL01KRV001V5.  Thank you for your help.
#spirit1
Nickname1920_O
Jan 14, 2015 8:42 AM UTC
Posted on January 14, 2015 at 09:42
maybe there's a misundarstanding: the SPIRIT1 USB Dongle is the demonstration board described here:
http://www.st.com/web/en/catalog/tools/FM116/SC1075/PF258713?s_searchtype=keyword#
and whose part number is STEVAL-IDS001V5.
Instead, the STEVAL-IKR002V5 SPIRIT1 Evaluation Kit contains:
  • Two SPIRIT1 RF modules (tuned @915/922 MHz Band)
  • Two motherboards with STM32L microcontroller
  • Two antennas
  • Two USB cables
This kit is described here:
http://www.st.com/web/en/catalog/tools/PF259026
So, to use the kit, take one RF module and plug it into one motherboard, and connect the motherboard to a PC by means of the USB cable. Do the same for the remaining RF module/motherboard.
You can find the related User Manual here;
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00092275.pdf
Regards,
Gaetano Panvini
