rdscliff
Jul 23, 2016 2:31 AM UTC
SPI and BlueNRG sleep mode
Posted on July 23, 2016 at 04:31
After SPI bus activity stops, how long until BlueNRG goes into sleep mode?
Document
UM1755 BlueNRG Bluetooth®LE stack application command interface (ACI) implies the time is 2 mS.  This is important because there is an errata saying that BlueNRG will lockup if a new SPI command is started while the BlueNRG is trying to go to sleep.
Nick Ushakov
Dec 13, 2016 10:01 AM UTC
Posted on December 13, 2016 at 11:01
Use the function Hal_Write_Serial of an example
http://www.st.com/content/st_com/en/products/embedded-software/evaluation-tool-software/stsw-bluenrg-dk.html
in file SDK_EVAL_Spi_Driver.c, this algorithm fixes lockup, if a new SPI command is started while the BlueNRG is trying to go to sleep.
