pagano.paganino
Nov 18, 2016 10:27 PM UTC
SPBTLE-RF FW 7.2c
Posted on November 18, 2016 at 23:27
i have a problem using SensorDemo_New of BlueNRG DK 2.0.2COPY_ENV_SENS_SERVICE_UUID(uuid);
ret = aci_gatt_add_serv(UUID_TYPE_128,  uuid, PRIMARY_SERVICE, 10, &envSensServHandle);i get ERR_UNSPECIFIED_ERRORif change max_attr_records to 7:
ret = aci_gatt_add_serv(UUID_TYPE_128,  uuid, PRIMARY_SERVICE, 7, &envSensServHandle);i get ERR_UNSPECIFIED_ERROR when call:
/* Humidity Characteristic */
  if(sensor_board){
    COPY_HUMIDITY_CHAR_UUID(uuid);
    ret =  aci_gatt_add_char(envSensServHandle, UUID_TYPE_128, uuid, 2, CHAR_PROP_READ, ATTR_PERMISSION_NONE, GATT_NOTIFY_READ_REQ_AND_WAIT_FOR_APPL_RESP,
                             16, 0, &humidityCharHandle);Any suggest?
Regards,
D.###############################################################################################Solved with correct max_attr_records (19) and correct char_value_len of the added gatt char.
Temperature char: char_value_len = 1
Pressure char: char_value_len = 2
Humiduty char: char_value_len = 2
Regards,
D.
