hyusim park
Oct 19, 2017 2:29 AM UTC
SPBTLE-1S Program
Posted on October 19, 2017 at 04:29
Hello, Mr, Ms.
I want to program SPBTLE-1S.
I want to use the bluetooth module to send signal from MCU to Smartphone.
To do that, do I need to program the SPBTLE-1S?
How can I do that?
I can not find any evaluation board for SPBTLE-1S.
And I want to program through MCU, where can I get the port and registor information ?
Is there any example code for SPBTLE-1S?
Could you please help me to use this SPBTLE-1S Module?
    Antonio Vilei
    Oct 19, 2017 8:48 AM UTC
    Posted on October 19, 2017 at 10:48
    Dear Hyusim Park,
    you can use the
    http://www.st.com/content/st_com/en/products/evaluation-tools/solution-evaluation-tools/communication-and-connectivity-solution-eval-boards/steval-idb007v1m.html
     board, which is based on the SPBTLE-1S module.
    In order to get familiar with how to program the BlueNRG-1 chip (the one inside SPBTLE-1S), you can use the
    http://www.st.com/content/st_com/en/products/embedded-software/evaluation-tool-software/stsw-bluenrg1-dk.html
    software package.
    Best regards,
    Antonio
    Antonio Vilei
    Feb 9, 2018 5:54 PM UTC
    Posted on February 09, 2018 at 17:54
    Dear
    hyusim.park
    When using the EVAL-IDB007V1Mboard, you have to change the setting for the 32 MHz crystal used in the SPBTLE-1S module. The BlueNRG-1/2 DKis preconfigured for the EVAL-IDB007V1 board, which has another crystal (16 MHz).
    Please make sure that in your project settings you use this setting:
    HS_SPEED_XTAL=HS_SPEED_XTAL_32MHZ
    The default configuration for the projects in the BlueNRG-1/2 DK, instead,is fora 16 MHz crystal (HS_SPEED_XTAL_16MHZ).
    Best regards,
    Antonio
