argonnedroid
Feb 4, 2016 10:02 PM UTC
SP1ML: RSSI at 1 meter is too low (-90 dBm)
Posted on February 04, 2016 at 23:02
I have two SP1ML modules, transmitting 11 dBm. If they are really close (1 cm), the RSSI is around -30 dBm,  when the distance is 1 m, the RSSI goes down to -90 dBm.
It seems that these values are too low. Anyone can help?
pavan shah
Mar 21, 2017 8:46 AM UTC
Posted on March 21, 2017 at 09:46
hi, were you able to work this out? what is the range of communication that you got?
