CKim.18
Jul 2, 2020 5:07 AM UTC
S2LP Sigfox Test Command ( SIGFOX_API_start_continuous_transmission)
I have testing SigFox Test command for SIGFOX_API_start_continuous_transmission / SIGFOX_API_send_test_frame.
but, Interrupt is not received after Send CMD_TX(0x60).
PLS let me know the procedure for calling this function.
for example
1.ST_RF_API_set_pa
2. SIGFOX_API_set_std_config
Thanks, CK
    BPRAS.1
    Mar 3, 2021 9:15 AM UTC
    Are you using SDK 1.7.1?
    What is the "sfx_error_t" in the function "SIGFOX_API_start_continuous_transmission"?
    What is the hardware used?
