bvn123
Jan 29, 2019 7:16 AM UTC
S2-LP SDK, SDK_Configuration_Common.h contains Radio configuration parameters & Packet configuration parameters. Q: How these parameters influence on the communication range and reliability of data transceiving?
I use two boards STEVAL-FKI433V2 with S2-LP and S2LPLibrary_Examples.
The file SDK_Configuration_Common.h contains Radio configuration parameters & Packet configuration parameters.
I want to increase the communication range and reliability of data transceiving and I know the Radiotechnical methods to do that.
But how the Modulation Mode, Datarate, Frequency deviation or Bandwidth influence on communication range, or Packet configuration on reliability|possibility for data restoration?
