Winfred LU
Mar 25, 2019 1:45 AM UTC
Hi Nasramine,
Please take a look at X-Cube-Sub1,
which includes diddleware library with Contiki OS and Contiki 6LoWPAN protocol stack
with ability of mesh networking.
https://my.st.com/content/my_st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-subg1.license=1553344373402.product=X-CUBE-SUBG1.version=3.1.0.html
Thank you.
Best Regards,
Winfred
BMoha.19
BMoha.19Author
Mar 25, 2019 8:23 PM UTC
Thanks a lot for your Answer.
In X-Cube-Sub1 i didn't found a complete example with mesh networking. Examples under "X-CUBE-SUBG1\en.x-cube-subg1_firmware\STM32CubeExpansion_SUBG1_V3.1.0\Projects\Multi\Applications\Contiki" didn't describe how to create mesh network
I saw that we have mesh api such as mesh_open, mesh_send..., should these APIs be called just after Stack_6LoWPAN_Init in each node?
Thanks a lot in advance.
Winfred LU
Mar 26, 2019 3:52 AM UTC
Hi Nasramine,
For Contiki's mesh samples, please refer to Contiki's document
http://contiki.sourceforge.net/docs/2.6/a00011.html
Best Regards,
Winfred
BMoha.19
BMoha.19Author
Mar 26, 2019 6:22 AM UTC
Hi Winfred,
Thanks for Contiki's mesh samples.
All mesh APIs (mesh_open, mesh_send...) should be called after calling API Stack_6LoWPAN_Init (otherwise S2_LP transceiver will not be started and mesh cannot be established)?
Mesh code deployed in each node will be something like this:
int main()
HAL_Init();
SystemClock_Config();
HAL_EnableDBGStopMode();
MX_GPIO_Init();
USARTConfig();
#if MCU_LOW_POWER
if (USER_CLOCK_FREQUENCY != DEFAULT_CLOCK_FREQUENCY) {
   HAL_RCC_DeInit();
   LP_sysclk_config(USER_CLOCK_FREQUENCY);
   MX_GPIO_Init();
   HAL_UART_DeInit(&UartHandle);
   USARTConfig();
#endif /*MCU_LOW_POWER*/
/* Initialize LEDs */
BSP_LED_Init(LED2);
RadioShieldLedInit(RADIO_SHIELD_LED);
BSP_PB_Init(BUTTON_USER, BUTTON_MODE_EXTI);
/* Initialize RTC */
RTC_Config();
RTC_TimeStampConfig();
_print_fw_info();
Stack_6LoWPAN_Init();
mesh_open(&mesh, 132, &callbacks);
Thanks to correct me if i'm wrong
Best Regard,
Amine
BMoha.19
BMoha.19Author
Apr 5, 2019 7:48 PM UTC
Hi Winfred,
Any news please?
Best Regard,
Amine
Winfred LU
Apr 8, 2019 1:16 AM UTC
Hi Amine,
You've got the entry.
Please try to replicate Contiki mesh example.
Best Regards,
Winfred
