Deepak.Aagri
Aug 14, 2022 11:24 PM UTC
RSSI value not changing in BLE Mesh Network?
Hello ST,
@EMECH​ ​
I am using BLE_MeshLightingProvisiner sample project. We try to trace the RSSI value from the below mentioned function::
 BLEMesh_NeighborRefreshedCallback(const MOBLEUINT8* bdAddr,
                     MOBLEBOOL provisioned,
                     const MOBLEUINT8* uuid,
                     MOBLE_ADDRESS networkAddress,
                     MOBLEINT8 rssi)
>>> NeighborRefreshedCallback function RSSI value 29
BLEMesh_CustomBeaconReceivedCallback(const MOBLEUINT8* bdAddr,
                       const MOBLEUINT8* data,
                       MOBLEUINT8 length,
                       MOBLEINT8 rssi)
>>> CustomBeaconReceivedCallback function RSSI value is 2
Both values are constant and not changing with LPN device displacement.
Is there any configuration require in project to get the right RSSI value?
Note: Purpose of this test to get the distance b/w prvn and lpn node in cm.
Thanks!
Best Regards
Deepak Aagri
CBuch.1
Jan 20, 2023 10:19 AM UTC
@Deepak.Aagri​ have you found an solution for this problem of constant values?
I have the same problem and the RSSI Value is constant 29 and not changing at all on he NeighborTable.
