DBhut.1
Senior
Jun 2, 2023 9:34 AM UTC
RS485 3.3V or 5V IC For Larger Distance
Our application needs longer distance RS485 communication, So, From 3.3V and 5V RS485 IC (available in ST), which to choose for larger distance coverage?
Thank You
    S.Ma
    Principal
    Jun 4, 2023 2:33 AM UTC
    Quantify larger distance, m, km?
    As ADSL, differential pair signaling is better and unrelated to voltage.
    Maybe check single pair ethernet using an ethernet pinout compatible transceiver for half duplex mode. Check Click board portfolio from mikroE
    Jun 4, 2023 2:06 PM UTC
    4000ft / 1.2KM
    https://www.analog.com/media/en/technical-documentation/data-sheets/491fa.pdf
    LoS LoRa should be able to get several KM
