Aug 19, 2026 09:14 UTC
RHFLVDS31A Unused I/O pins
Im using the RHFLVDS31A  and I have some unused I/O pins. Should I terminate them or should I leave them floating? I saw that there is an internal pull up for Cold Sparing so I didn’t want to impact that.
Peter BENSCH
Peter BENSCHBest answer
Aug 19, 2026 10:58 UTC
Welcome ​@Lobert124, to the community!
I am not a Rad-Hard specialist; however, it is always advisable to terminate unused digital inputs if they are not already terminated with internal pulls, as in the case of G and /G. Whether the outputs need to be terminated will probably emerge from your application’s requirements specification.
Cold sparing has nothing to do with pull, but rather, as the datasheet states, are "buffers to ensure they are in high impedance when VCC is tied to GND".
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
Lobert124Author
Aug 19, 2026 11:26 UTC
OK sounds good Peter, I just wanted to double check in case there were some internal ESD or pull up that wasn’t mentioned.
