AMoro.16
Aug 4, 2019 5:30 AM UTC
Reference circuit for STA8090WG, how to communicate with it
HelloI I've read datasheet of STA8090WG, but intead of clarity, many questions arose. First of all, is this chip come with preintalled firmware, or I shoud flash it by myself?
Whether there is a reference circuit for this chip?
Which interface I should use to communicate with device: I see that device have USB, I2C, UART. But there is no information about communicate with device. For example, which I2C address I should you to access to this chip?
Which commands I should use to communicate with it?
AMali.2
Apr 14, 2020 7:51 PM UTC
any answer for this issue
I have a same issue also for STA8090WG . Datasheet and documentation is not good
Apr 14, 2020 7:57 PM UTC
Expect to be doing $1M in business with ST to get access to technical docs and engineering support.
Contact your local sales office to determine if you are a qualified customer for these ICs
Probably want to start with an evaluation board, and get the design documentation for that
https://www.st.com/en/evaluation-tools/evb-t3.html
