Jul 15, 2024 7:15 PM UTC
Questions about using BLUENRG to write into SD card
Hi everyone,
I've recently using the BLUENRG-LPS chip for transmitting and receiving data, and I need to store the data from the chip directly into the SD card. Does the BLUENRG-LPS have the SD card driver?
I found the STML4xx SD card driver in the BlueNRG-LP_LPS DK, which means the BLUENRG chip needs to work in coprocessor mode, but I haven't found the driver directly for BLUNRG-LPS. Is there a way that I can write the data into the SD card from the BLUENRG-LPS chip directly?
Thanks very much!
