Lorenzo Pecci
Jun 28, 2017 3:12 PM UTC
Python on SPWF04S
Posted on June 28, 2017 at 17:12
Hi, I have a problem with SPWF04S.
When send command 'AT+S.PYTHON' the answer is 'AT-S.ERROR:16:Cannot switch to Python shell'
I tried to look something in datasheet, but nothing. I dont know how go over. Any idea?
#python #spwf04sa
    Elio Cometti
    Jun 29, 2017 7:06 AM UTC
    Posted on June 29, 2017 at 09:06
    please check the value of 'console_enabled' configuration variable. It must be '2' to enable uPython and '3' to boot from the python script specified in the 'python_script' configuration variable.
    You can find these and more details in the application note 'AN4964: MicroPython scripting language over SPWF04S'
    Lorenzo Pecci
    Jul 3, 2017 9:43 AM UTC
    Posted on July 03, 2017 at 09:43
    As I said, I followed the istructions in the application note. Therefore, I set 'console_enabled' to '2' but the answer is like this:
    And I checked the value of 'console_enabled':
    Lorenzo Pecci
    Jul 3, 2017 10:01 AM UTC
    Posted on July 03, 2017 at 10:01
    I found a solution. After change 'console_enabled' to 2, I need to save the configuration variable to no volatile storage (AT&W).
    Restart the module and now shell started.
    Thanks for the support.
