Jan 10, 2025 10:43 AM UTC
potting BLUENRG-M2SP and BLUENRG-M2SA
I hope you are well.
I am using your bluetooth modules with chip antenna “BLUENRG-M2SA” and PCB antenna “BLUENRG-M2SP”.
I'm going to put the 2 modules in the potting ? is there an influence of potting on the characteristics (range, transmission, power ...) of the chip and PCB antennas ?
What is the best antenna type and the least influenced by potting?
Thanks in advance
Andrew Neil
Jan 10, 2025 11:16 AM UTC
Have you asked the supplier of your potting material?
You'd want to know its properties at 2.4GHz ...
ljmAuthor
Jan 10, 2025 12:27 PM UTC
Hello
thank you for replying
I haven't chosen the potting yet, which is why I asked you.
Please, what are the potting parameters that can influence the antenna?
is the chip antenna better than the PCB antenna in potting?
Thanks in advance
