justin23
Perform HTTP Get with listed parameters
Posted on August 11, 2016 at 09:40
I need to perform an HTTP Get request to a server that supports listed parameters, an example being:
myshop.com/storesrequest.aspx?userid=1234&zipcodes=123,456,789
As you can see the zipcodes parameter supports a list of values separated by a comma.
The problem with this is that the SPWF01S interprets the comma as another configuration parameter for the HTTP Get command.
The server is a fixed third party server and cannot be changed.
Is there a way to issue an HTTP Get that contains commas?
#httpget
    Gerardo GALLUCCI
    Posted on August 11, 2016 at 12:52
    Use console1_delimiter configuration variable to change default ''comma'' (0x2c).
    If not available, update FW release.
    justin23
    justin23Author
    Posted on August 11, 2016 at 13:30
    Perfect, exactly what was needed. Thank you. I'll remember to look for the latest documentation next time.
