Feb 19, 2024 4:57 AM UTC
PCB gerber file of BlueNRG-332AC
I am currently designing a PCB with bluenrg332AC and need the layout / Gerber file to make progress. But I couldn't find any on the Internet, so can anyone provide me with the file or give me some hint of finding the file? Thank you!
Peter BENSCH
Peter BENSCHBest answer
Feb 19, 2024 10:34 AM UTC
You will find information in AN5526 (PCB design guidelines for the BlueNRG-LP, BlueNRG-LPS devices), as well as in the evaluation boards STEVAL-IDB012V1 or STEVAL-IDB013V1.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
Andrew Neil
Feb 19, 2024 10:40 AM UTC
What do you mean by that?
If you are designing a PCB, that means that you are creating the layout!
And the Gerber file will be the output from your PCB tool when you have created that layout.
