rdscliff
Aug 2, 2017 10:40 PM UTC
Open bugs related to ID 2131 - bonding
Posted on August 03, 2017 at 00:40
Are there any open bugs related to ID 2131: Slave abruptly disconnects if any non-empy packet is received after an encryption failure?
I'm bonding a device with an iPad using the 'just works' model.  After clearing the bonded list on both the iPad and the device, bonding proceeds fine with no errors.  But after a disconnect and reconnect, the application sends ACI_GAP_SLAVE_SECURITY_REQ and I get the symptom described in release note: The slave sends a HCI_DISCONNECTION_COMPLETE_EVENT to the application, with Reason=0x3D (Connection Terminated Due to MIC Failure).
Any work arounds or is this a new bug?
