srikanth
Dec 18, 2021 7:08 AM UTC
no stm32 target found while connect st link v2 to target
we are trying to program a hex file by using st link v2 programmer in cube programmer getting follow error.
no stm32 target found.
also I updated the firmware.
the target board is working with another st link.
from not working st link we are getting TCK but TMS not getting.
may be what is issue ?
    Uwe Bonnes
    Chief
    Dec 18, 2021 1:29 PM UTC
    Tripple check wiring, try connect under reset, try other debuggers or debug-programs for the stlink.
    srikanth
    srikanthAuthor
    Dec 20, 2021 5:53 AM UTC
    thank you for reply
    we checked with other stlink programmers and working fine.
    we tried under reset mode only and all wiring has fine.
    Dec 18, 2021 1:49 PM UTC
    The failing ST-LINK is a dud?
    Could be damaged at connector or cable.
    Try a lower connection speed.
    What type of STM32?​
    srikanth
    srikanthAuthor
    Dec 20, 2021 5:52 AM UTC
    thank you for reply
    we connected with 240kHz low speed only.
    cable is working fine.
    we tried with stm32h750 MCU.
    here which connector we need to check ?
