SMauc.784
Nov 4, 2019 1:18 PM UTC
Manual Control of VBUS_EN_SNK of STUSB4500?
we want to have a possibility to disconnect the USB-C supply manually.
Can we use the VBUS_EN_SNK signal and disable the corresponding mosfet manually?
The datasheet is somehow unspecific.
Is the VBUS_EN_SNK signal undriven when we set the device via I2C to the reset mode?
Thank you very much.
