Jan 30, 2024 9:34 AM UTC
L9663
Direct interface of communication interface Is the transceiver directly connected to the PSI5 interface of the ECU
SCONI.8
May 20, 2024 1:05 PM UTC
In Mode2 configuration, L9663 Doutx pins output the Manchester-encoded voltage signal of the received sensor(s) data transmission. You should verify the MCU peripheral requirements (and configuration) for the connection details.
