TNils.1
Sep 7, 2020 11:57 PM UTC
Is the STUSB4710 VBUS enable mandatory?
Hi
Is it possible to use the STUSB4710 without the VBUS_EN_SRC switch? In such a way the the VBUS is always sourced from the supply side.
I expected this to work, but when I tried it on the STUSB4710A evaluation module, it seems it will not set any PDO's.
Any way to get it to work, or am I forced to use this switch?
The external Discharge I have understood is not mandatory, as there is an internal one, right?
This is for a DFP only application.
Thanks, Thomas Nilsson
    TNils.1
    TNils.1Author
    Nov 12, 2020 12:56 AM UTC
    no one?
